Question about Lefroy Brooks Bath Waste Trap for Exposed Fitting Complete with 500mm Exten
Bathtub drain leaking
Bought an older home, have had two plumbers out to fix an upstairs tub drain that was leaking but they couldn't find the problem! Turns out, it leaks only when in use. And leaks into the downstairs light fixture. I'm a teacher and can't afford to keep hiring plumbers. Can you help me?
    Scholar:
  • 68 Answers
Since two plumbers have tried and failed, I'm assuming that the problem is none of the obvious ones. I have two ideas for you, the second being the most effort, but also the most likely.
(1) If you have ceramic tile on the walls around the tub, sometimes cracks between the tiles will develop or the grout itself will develop leaks (become very porous). This would not necessarily show visible cracks, but could appear to be a drain problem since it will only leak during/after use. For this, you would need to patch the grout where needed and seal it well.
(2) You may have a leak in the piping under the tub. Since you mention a light fixture downstairs under it, it is likely that you can "create" access to the piping. This would require cutting a section of drywall out immediately under the drain and approaching the light fixture, about a foot wide should be enough to give you a decent look. Cut the drywall carefully so you can use the same piece to close the hole, with a little spackle, when you are done. Once open, turn on the water and watch to see where the leak is coming from. At that point you (or a plumber) should be able to identify what to do.
If your older house is "really" older and you have plaster instead of drywall, do the same thing, except you obviuously can't use the old plaster to fix the hole when you are done.
Posted on Jun 26, 2009
    President:
  • 3,433 Answers
Hi Teach :)
Do you know where the lek is? Like in the drain piping or at the draing ring? I would be glad to do what I can but you are there and I am here. That in itself is a problem. Do you have access to the drain plumbing? Is it metal or PVC? We do need some specifics. If you have a cam cell phone and can take a pic of where the suspected lek may be. Send to co7196@yahoo.com. I'll be glad to assess your predicament. Make sure the pics are clear with good lighting and if possible mark the point in question. Ned
    Problem Solver:
  • 19 Answers
The two plumbers you hired did not locate leak nor did they fix anything and as a plumber I would not have paid them anything to come out and not fix anything.? However, the leak may not be the drain but the tub spout or shower head fixtures or pipes behind them. As the other solutions you have to locate the leak to fix it which may require cutting the back of shower valve wall if you have access to do so which would give you a visual to both if you cut low enough to see drain and water leaks from above its most likely the fixture plumbing. If you cant cut from behind then from underneath which I ask you to please cut off breaker to that light to avoid shock.
Posted on Jul 09, 2009
Leaking at jet to tub connection
You can fix that with a small amount of "plumber's putty". You have to remove the jet from the tub first, then smear the plumber's putty around the junction where the two meet each other, then reassemble.
Aug 04, 2014 | Jacuzzi Home
I accidentally clogged my bathtub.
Liquid plumber or a good quality drain opener should disolve the foam things. Pour about a pint in and let it set for about 30 minutes, then flip the stopper up to seal off the drain. Run about 1/2 the tub full of hot water, open drain, and plunge rapidly with a plunger. This should fix your problem....(plumber 20 years)
Jun 11, 2012 | Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
I have installed the bathroom sink according to the directions (which need words along with the pictures) and the drain leaks. I used plumbers putty around the lip of the drain (instructed to by Menards)...
the sink drain through basin. you can use chaulking compound like for tubs. remove drain put a bunch of chaulking on drain outlet of sink, under drain on bowl of sink. let sit for approx. 10 minutes, then replace drain and tighten down. have a good day !!
Jul 11, 2011 | Moen Home
The tub drain is installed but it is leaking around the flang not the stopper itself? i am assuming it is leaking outside the drain ? which appears to be in the room beneath it.. 2nd floor tub.... Do...
If it is leaking from around the flange then you will need access to the under side of the tub drain to 1) tighten the drain connection or 2) replace the tub drain connection or 3) remove the drain, clean it and replace it again properly with the rubber washer and plumbers putty.
Nov 06, 2010 | Home
We are ready to install the Duracraft Plastics Schedule 40 Foot Lok style bath drain and have a question on the foot lok drain gasket. Does the gasket install on the inside or outside of the bathtub and...
The gasket is installed on the outside of the tub. Use plumbers putty under the male end on the inside of the tub as it stays permanantly flexible and will not mildew like silicone caulking can. Do not silicone or use plumbers putty on the gasket. The gasket will seal nicely under pressure from the connections.
Aug 02, 2010 | Home
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
My upstairs tub leaked and can see large water stains on the first floor ceiling. I think it only leaks if the jets are turned on. how do you fix this?
you will want to fill the tub up and turn the tub on first and get behind the tub and see where the water is coming from. there isn't any other way to find the leak.
Oct 15, 2009 | American Standard Home
Water leaks from around drain in our korral whirlpool tub. Also from around the light that is in tub. Our local plumbers say they cannot find replacement parts..can it be fixed by just using plumbers...
Use of plumber putty should do the trick. take it apart clean it well and apply the putty. For the light, use silicon glue. You can get a tube at any hardware store. There are many different kinds, just read the label and find one for bathroom use. clean around the light and apply. If your unit is white use white silicone, if it is a color use clear.
Hope this helps.
Aug 27, 2009 | Home
Water is leaking from bath tub drain
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
Apr 26, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Lefroy Brooks Bath Waste Trap for Exposed Fitting Complete with 500mm Exten Logo
1,156 people viewed this question
Top Lefroy Brooks Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Lefroy Brooks Plumbing Expert? Answer questions, earn points and help others
