Question about Sony KDS55A2000 55" HDTV
Cleaning mirror of sony kds55a2000 rear projection tv then what
To do after removing all inputs and screws from edges should the tv be laying on it's front ,screen down?does the back lift up with the mirror?
tvtechnician
  • 105 Answers
SOURCE: Sony Grand WEGA KDF-50WE655 Parts Numbers Needed
1-788-159-21
1-788-162-21
A-1087-018-A
here are your part numbers for the 2 screens and mirror
Posted on Oct 14, 2007
SOURCE: rear projection clean mirror
I just cleaned my 4 year old panasonic PT47WXC43G's mirror and bulbs using alcohol free baby wipes and a microfiber cloth to dry them off. I did this because my tv started to look like crap. The picture was extremely foggy. I had incredible success doing this! Saved me about 2 grand. Now I don't have to buy a new TV now! My picture looks just like it did the day I bought the TV....If not better!
Posted on Feb 28, 2008
  • 395 Answers
SOURCE: Sony KDS55A2000 - 55'' Widescreen Bravia HD Ready Rear Projection TV
hit the display button on the remote
Posted on Apr 14, 2008
  • 395 Answers
SOURCE: cobweb inside of TV
remove the front panel there is a thumb screw in the back on each end to remove. then remove the screws from the back along the screen. remove 4 screws from the front bottom of the screen. remove the screen and use a soft cloth to clean the inside cavity.
Posted on Jul 25, 2008
  • 4 Answers
SOURCE: Sony 50 inch rear projection television
NO IF YOU DONT TAKE CARE AND PUT SOME UNDER
Posted on Jan 19, 2009
How do i clean mirror on a sony KP-57ws520
Fairly easy to do.
Follow these steps:
1) Unplug the TV
2) Remove the lower access panel (the pressboard with all the holes in it) by removing the screws holding it in place. (This is the panel where where your connections are made)
3) Remove all the screws on the big black shroud on the back that actually holds to mirror. There are probably about 15 screws.
4) gently lift the panel off and set in on the floor or table where you can clean the mirror. (remember the mirror is attached to the back side of it) I usually put in on the floor.
5) clean the mirror with glass cleaner or non-streaking solution.
Reverse the steps above to re-assemble.
Feb 18, 2011 | Sony KP-57WS500 57" Rear Projection...
Tip
How to replace a broken projection TV mirror.
You were moving your projection TV and drop it, breaking the mirror.Where can you get a replacement and how do you remove and replace the bad mirror safely and properly?
First be aware that the mirror is delicate and removal and replacement should be done very carefully while wearing leather gloves and safety glasses.
Go to http://www.encompass.com to locate and order your mirror. They have good prices, availability and a great search engine. Now most service manuals are also available as a free pdf download. The service manual will help find the screws needed to be removed to complete the job, infact it should have a section devoted to procedure for mirror replacement. If encompass does not have the service manual, they have most but not all, I would recommend purchasing it at http://www.servicemanuals.net for about $16.00.
Installation is straight forward. Generally you have to remove the back top cover with the mirror attached. On some units the bottom rear must be removed prior to removing the top. Requires removing alot of screws. There could also be some screws under the bezel on the front, below the screen. This varies from unit to unit and this is why the service manual is necessary for this job.
Remove the rear top section containing the mirror and lay it upside down on the floor. You should be looking at the mirror in the top rear section at this point. Remove the mirror hold in screws or clips. Again having the service manual makes this part easier. Remove the mirror being careful not to break it and cause a safety hazzard.
Install the new mirror, after cleaning with a soft cloth and a non-ammonia surface/glass cleaner such as Cinch or Windex.
While you have the unit apart you should clean the lenses and the rear of the screen.
I have a tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv which will walk you through the process. This should complete the job.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Feb 27, 2011 | Televison & Video
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
Bog and dust on mirror....showing up on screen, how best to clean?
remove pointy screws out of back of screen ( 3 up each side and 4 across top). remove speaker grill, remove 4 screws from center cover. remove 4 screws from bottom of tv, disconnect wire bundle. lift screen up and off. clean mirror facing up and lens. Do NOT touch big mirrror, trust me. put it back together by sliding screen back on and making sure all edges are flush before putting screws back in. the pointy ones go in the back every other screw is flat. good luck, should only take about 5 minutes.
Dec 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Back of tv
Yes, start with unpluging the set. lol remove the lower rear cover first by removing all of the screws around the oustside edges, left-right-top-and next to the input panel. then remove all the screws around the edge of the top of rear cover. Be carefull because the top rear cover contains the mirror!! There is no way to make the bottom of the set any smaller other than removing the speaker grill in front. (usually this is just a snap-on cover.
Sep 18, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Mitsubishi 55'' rear projection 1080i hd tv lense cleaning
Pry off the lower speaker grill... Remove the screws at the lower edge of the screen framing and lift screen frame of the two catches at the top. Be careful, there will be wires still attached to the front button panel... Then lay the screen down and support the bottom of it in some way because the button panel wires won't reach all the way... then using windex and papertowel cleam the mirror and lens(s) on each of the crts. Also clean the back or inside of the screen area and reverse the process to re-mount the screen.
Bill
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Sony KDS55A2000 55" HDTV Logo
308 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
