TV doesn't power on, it clicks and blinks 10 times then clicks and blinks all over again, Power Supply is regulating all correct volts to each and every board as it should be! It was working yesterday but today came turned it on and had this problem! If any suggestion or tips would be great!
Take a look on your telecomand (tv control)
Testimonial: "Yes that was exactly the Problem! Thanks So Much!"
Replace the capacitors on the power board here is the link. This will save you a lot of money
Samsung LN46A540 LCD TV Repair Kit Capacitors Only Not the Entire Board
Testimonial: "The Capacitors are Fine! There are all working Correctly! Already Checked that! Its not the Problem.."
I had the same TV with the same problem. Replaced capacitors and it has worked ever since. The only way to test a capacitor is to remove it and ise a capacitor tester. Did you do that if not then you can not say that they are fine.
It was the TV Control Board! The Power Supply was Fine!
Thanks Anyways!
can capacitors cause tv not to come on at all? mine is listed under lawsuit and was coming on and blinking and clicking then nthing. so put it up and started researching. got it back out and damn thing came on! so i hooked it back up and sterted watching it to see how many blinks and which lights but it worked fine for one week. it took two tries to power up the last time it came on but then nothing. no lights no blinks no noise just like last time it died.
