SOURCE: peugeot 405gl 89 miss firing
block distributor vacuum pipe,and the difference also check fuel filter free of water.
SOURCE: Smell of gas fumes underneath vehicle near fuel tank
this sounds like a gas pressure regulatur. a few minutes after starting,you start smelling fumes,and are getting bad gas mileage right?
SOURCE: My 2003 Mazda 6 has a very strong petrol smell
Well you mechanic has obviously not done his job , on some cars there is a vent tube that runs ajacent to the main filler tube there may be a breach in the rubber hose or where it connects, but more than likely the purge canister located in the engine compartment is faulty not allowing the gas tank to vent, have the purge canister checked.
SOURCE: Oil leak. CHecked filter and
check for oil presser sensor leaking these things will leak right threw to the wires even so unplug and look real close and when u change filter make sure to wipe mateing surfaces
