FixYa.com
Tags:
Nikon D100 Digital Camera
Nikon d100
posted by GLIDDS on Nov 05, 2007
how do i manually expose using 500mm f8 mirror
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 30, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
using that kind of lens on the D-100, You will not have a meter to use! What I do is guess at the shutter speed, take my shot! If the exposure does no look right! go a step up or down till ya get it right! with practice this will get easier and you may get it right on the first shot!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 14, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Hi, I´m using manual lenses on D100, and since I like to shoot RAW, the buffer size is limiting. What i tend to do (if I have the time) is to take a series of testshots in jpeg basic, check the histogram until I find the best exposure, switch back to RAW and do my final shot(s).
Solution #3
posted on Nov 26, 2007
Not Rated (0)
eastpole
Rank:Guide Guide
Rating: 95%, 6 votes
Wow, that's a long lens! It it a Nikon 500mm?
I use the full manual mode on my D70 sometimes, and I think the operation will be very similar. Spin the mode dial to M, first.
Now half-press the shutter and you should get metering at the bottom of the viewfinder. The meter will tell you if your current settings are over or underexposing. You can use the front control wheel to set the shutter time, and the back (thumb) control wheel to set the aperture.
If you've used S or A modes before, you'll be familiar with these controls. More aperture (smaller F numbers) lets in more light, as does (obviously) increasing the shutter exposure. If not, play around and watch what happens to your exposure meter in the viewfinder as you dial aperture and shutter duration up and down.
You're going to want a sturdy tripod or some very bright light with a lens that long!
You may have to use manual focus, too, if your lens does not have modern Nikon guts for the camera to talk to. I guess you'll cross that bridge when you come to it. Good luck!
Can you Help with these Digital Cameras problems?
camera operating slowly
camera operating slowly...card... Answer This...
TIPS to take arrange the menue...
respected sir, since 2 years 6... Answer This...
Getting a code of 1.1 with a K...
D100 instead of getting a shot... Answer This...
shooting in continuous mode...
When I try to use the... Answer This...
Nikon D100 lens interface...
I have a Tokina 80~200 F2.8 ATX... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
