Question about Shimano Citica 200E/Cabela's Fish Eagle II Casting Combo
My merc 9.9 outboard starts right away, as long as
I bought a used Merc 9.9 outboard motor. It starts right away, as long as I throw it into gear. it runs fine thereafter. If i shut off the motor, it won't restart. any suggestions?
    Champion:
  • 207 Answers
You need to plurge you carb and make sure your choke is working the way u plurge your carb is pull the drain screw on the bottom of carb and pump yuor hand ball on your fuel line this will run any excess oil,water or crude out of the carb you need to check you idle by pulling the throtle cable off and turn the brass or black barrel to the right to up the idle if that doesnt work you need to pull the carb and run a peice of a wire wheel through the pilot jet witch is the smallest brass jet in carb if that jet is cloged it will not idle
Posted on Jun 27, 2009
Sounds like a blown fuse. Some systems use an "Ign" fuse. That means ignition. The reason why it starts, is the starter solenoid is powering the coil. There might be a ballast resistor in line to the coil. You could check that with an ohm meter.
Posted on Mar 09, 2010
1989 17' Four Winns, engine will run as long as the ignition switch is in the start position. Engine is a GM 6cyl chevy.
Posted on Sep 09, 2009
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
I have a 230 merc marine engine and when starting fuel is comming up through my carb causing boat not to start
remove the carby and clean out the rubber dirt under the float needle
marine outboards suffer a rubber degradation of all rubber parts and it blocks carby jets, needle and seat holes
IF you are interested in boating safety ,take it in to a merc service center and have the fuel system checked out properly
Aug 02, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
1996 9.9 merc fourstroke manual longshaft, need carb but there is no serial number on the outboard
in cases like this , I would take the boat into an merc service center and have the motor identified along with the carby
most outboard carbies suffer form form rubber bits blocking jets and corrosion from sea water in the fuel
check that the carby cannot be overhauled first as that may be a lot cheaper than a new unit
Nov 11, 2015 | Boating
9.9 merc outboard serial # 114058 what year is it ?
The best I can tell the year would be 1986.
Is the Serial number A114058?
Jul 03, 2014 | Computers & Internet
How do i get spark to my bottom to cylinders on my 4 cylinder 50hp pull start merc outboard
Merc has changed their ignition system on a "need to know" basis. So more info is better.
Sounds like you have lost a cdi box, or maybe have compression problems
Aug 15, 2012 | Boating
Outboard whirring noise when ignition is off
gears in lower .... from counter rotation of prop is back ward loading from hydro drag as i assume you were still moving . when you hearr this/
Mar 15, 2010 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Shimano Citica 200E/Cabela's Fish Eagle II Casting Combo Logo
480 people viewed this question
Top Shimano Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
John
Are you a Shimano Fishing Expert? Answer questions, earn points and help others
