Question about Motorola Televison & Video
How do i reset my dch3200 box/m-card.I have comcast. the box in my room works.The box in the front room just gives me this channel should be available shortly. Its been 3 hours
2 Suggested Answers
jmantoo
  • 4 Answers
SOURCE: Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Posted on Sep 19, 2009
Where is the serial number on Motorola dch3200?
MAC I D but I would use chat and they should help.
Mark
Motorola support
Jun 15, 2014 | Arris SURFboard SBG900 802.11g/b...
The botton for channel 3 or 4 do not work so i can hook up my dta box from comcast. is there a box in the back of the unit to open ?
use the channel up/down on the front of the tv to get to 3 or 4, or if your comcast box also has rca outputs, use those instead
Feb 08, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ref: Motorola DCH3200 Problem with channel input. When I enter three digit input, the response is painfully slow and the result is a wrong channel. For instance, when I enter 702 on the remote control, the...
Unplug the comcast digital box and wait 20 seconds or so, then plug it back it. I had the same problem and was given this solution and it worked. NOTE: the program guide will require at least 24 hours to "fill up" again. I was told that the problem is that the cpu in the digital box gets overloaded and needs to be rebooted/reset.
Hope this works for you
Sep 14, 2010 | Motorola Televison & Video
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Sep 11, 2009 | Motorola Televison & Video
MOTOROLA DCH-3416 FOR COMCAST: will it work if i buy one ..
no it will not work. It will have to be set up and flashed by comcast, so there is no way to use it with out them knowing it.
May 09, 2009 | Televison & Video
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
Mar 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
1,134 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
