Question about Brother MFC 420CN All-In-One InkJet Printer
I have a MFC-665CW error code 51 unable to clean
  • 3 Answers
Hi
Here's how I got rid of errors#50 and #51 on the Brother MFC-665CW, MFC440CN and like.
Open the 2 top-covers and locate the printer hole, a large horizontal hole near the back of the printer. The printer head is usually on the right and the cleaning pad, on the left. Locate them with a flash light.
For error #51 (Inkpad full): take some Scott-Towel and gently press on the cleaning pad. Be ready to fill several Scott-Towel sheets. Wear some gloves and/or have some "Clorex"/"Hertel plus" nearby to clean your hands.
For all errors, disconnect printer and move the head to the left. You may have to play with an horizontal bar with a gear at the right, near the printer head. The printer head get stuck in that gear and it pops error #50, but it can be unstuck gently by hands. Close covers and power-up. Expect 3-5min for the printer to clean-up. First sheets may not have all colors.
Posted on Jul 17, 2012
    President:
  • Brother Master
  • 1,447 Answers
Change your cartridge insert new cartridge then solve it please send me reply
Posted on Jun 26, 2009
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Posted on Jun 11, 2009
komguy
  • 2306 Answers
SOURCE: How do I clear
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Posted on Oct 02, 2009
Daniel S
  • 4323 Answers
SOURCE: Brother MFC-665CW has error code 51, no paper
Hi
Error code 51 means that there is due to wate ink pads which are full. You'll need to clean these pads to remove the error message. Also check for any small bits of paper stuck under the printhead (check under the carriage). Try removing the cartridges and check for any bits of paper. Before doing any of the above said things please turn off the printer and unplug it from power source.
If this doesn't work then its an issue with the purge unit. The purge unit is responsible for carriage movement on the chrome bar.
Please tell me if you need further assistance,
Daniel Scott
Posted on Jun 19, 2010
Brother mfc240c #51 cant print error code.What to do
https://www.easyink.co.nz/support/brother-mfc-665cw-unable-print-51-error-solved/
Sep 14, 2017 | Brother Office Equipment & Supplies
I have an error message on my Brother MFC-665CW--unable to print 51- how do I fix it
Unplug the unit and then plug it back in, check to see if the error message reappears, if it does go to the Brother web-site and check the error message information
Oct 19, 2014 | Office Equipment & Supplies
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Code unable to print 51
Hi, Error 51 means that the purge inkpad is full.
This means you have 3 choices:
1- If it's still under warranty, activate it 2- Replace the inkpad, but sadly Brother does not provide spare parts and as such it will be extremelly difficult to find a compatible one. 3-Get in contact with BROTHER to get an estimate of the cost to replace the ink tank.
Hope i was of any help. If so, please rate me. Thank you
PcSimples
Mar 14, 2011 | Brother MFC-665CW All-In-One InkJet...
My screen reads Unable to clean 51. The machine will not turn off or do anything. It is stuck. :I need help. I have ab Brother model MFC-665cw. This problem just happened. I have unpluggeds the machine...
Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
If we can find the code table we can work with these machines
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 18, 2011 | Brother Multi-Function Center MFC-665CW...
Unable to CHANGE 51
Cannot turn printer off and can't find a solution to this. I have seen unable to CLEAN before, but never unable to CHANGE. What is this and how can I fix it? Model MFC-420 CN.
May 02, 2010 | Brother Multi-Function Center MFC-240C...
How do I clear "Unable to Print 51" Error Code on a Brother MFC-665CW All in one Printer
Oct 02, 2009 | Brother MFC-665CW All-In-One InkJet...
Unable to clean 51
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Sep 25, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC 420CN All-In-One InkJet Printer Logo
739 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
