Question about Welding Tools
Feed switch came apart, seems to have lost spring out of wirewhip
Feed switch came apart,put it back together and now it seems to have lost spring or something that keeps wire feeding contacts together all the time . have to keep pulling out on the moving part of the switch to stop feed. welder is over 5 years old and i dont have manual to get part numbers off of . can switch be rebuilt or do i have to purchase new wire feed whip ?
  • 71 Answers
Sounds like you lost a spring i would just get a new gun
Posted on Aug 08, 2009
What is the proper configuration of the ryobi p2200 string trimmer head assembly?
Ryobi P2200 18 Volt Hybird String Trimmer Parts
Find Part By Symptom on right side
Select "Trimmer line feeds too much / continuous"
Will show you list of parts to hopefully fix you problem
Jul 22, 2017 | Ryobi Garden
Passenger power seat will not tilt back.
It sounds like the burnt switch problem that the Sedona's seem to have. If you are confident enough, and can take a switch apart, but you will be dealing with tiny springs and contacts etc. then take it apart and carefully clean the internal switch contacts (just a quick rub with fine wet/dry paper on the contacts will do it) The tricky bit is putting the switch back together. Other than this it could be a loose connection on the wiring plugs which I would check for first before tackling the switch, BEWARE do not take the switch apart in the car, take it off and do it where you are less likely to lose any bits. You could buy a new switch.
Jan 10, 2015 | 2007 Kia Sedona LX Minivan
I have a Makita MAC2400, it stopped working, didn't realize where the reset button was, took apart the on off switch thinking there may be a fuse, the spring made it all fall apart as soon as I took the...
The pressure switch is assembled by automation and is basically impossible to put back together by hand. Even if you did manage to get it back together, the adjustment if critical. Easier to replace with generic pressure switch. Order from ebay for about $15. Just pay attention to port size and cut-out pressure. Select a switch that has on/off ,several ports on bottom and cut-out from 125 -135 psi. Factory switch is too expensive and really not any better. Good luck
Sep 04, 2013 | Makita MAC2400 Electric Powered Air...
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
The switch to our 1959 came apart and we have the parts but need to know what order to put them back together
I am not aware of an exploded view of that switch. Most people buy a new one for $25 instead of trying to repair it.
It was used from 1950 to 1960 on most Ford Lincoln and Mercury models.
Jul 13, 2012 | Ford Cars & Trucks
I took my arrow ET200 nail master apart to remove jammed nails. I need a diagram on how to put it back together
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
Jan 24, 2012 | Arrow ET200 Electric Brad Nail Gun
My fax machine keeps jaming on the right side in the paper tray, what causese this
When it jams, does the paper get bent or crinkled? If so, there is probably something lodged in there causing the paper to stop. Could be a paperclip or staple, or maybe another piece of paper.
If there is nothing blocking the paper and it just stops feeding on one side, you may have a tension problem -- springs might be getting old and not pushing rollers together tight enough to feed the paper. If you can take the machine apart, try switching the springs around to see if that makes a difference.
May 26, 2010 | Brother IntelliFax-4100e Fax
Welding Tools Logo
88 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
