Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
I have to press the power button. The video is constantly blacking out for a few seconds and then retuns, i have audio during the blackout. The red light flashes 5 times over and over
  • Sony Master
  • 1,229 Answers
You need to look at the vertical IC on the main board. It has seven pins. Clean off solder from pins with solder wick. Clean off with flux remover. wipe clean and resolder the IC. This should repair set. This is a common problem with Sony TVS.
Posted on Jun 26, 2009
How to reset your pyle Astor
If there is no reset button behind the faceplate (usually small and either black or sometimes red ) Press it and hold it down with the tip of an ink pin for at least ten seconds , when you release it it should have reset your unit. If you don't see the reset button , just disconnect the power wire (red) and 12 volt constant power (yellow) for about 10 seconds as well. That should do it ! Good luck !
Feb 01, 2015 | Pyle Car Audio & Video
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
My alpine 9965E LCD display keeps on turning to black after a few seconds, but the head unit works. If i increase the volume, go to the next track, the LCD display pops out again
you have turned on the "black-out" feature to get it back look for a little button over the volume knob with either "dispay" or "blackout" on it. Press and hold it and you will hear a beep to let you know you changed it. Why Alpine put that feature in the head units is to confuse and comfound drivers is my guess.
Aug 02, 2009 | Car Audio & Video
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Nov 01, 2008 | BenQ FP91G+ 19" LCD Monitor
Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
