Question about Vehicle Parts & Accessories
Hello. I think my clifford alarm is stuck in valet mode. It will lock and unlock with the key fob but the alarm won't set. I tried to find a button combination on the internet to fix this, but have not been successful.
SOURCE: viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Posted on Dec 22, 2008
insanegtp
  • 112 Answers
SOURCE: Car Alarm
Key on, push the button, if that doesn't work, please post with model #, you can find that by looking under dash and finding system...
Posted on Jan 24, 2009
  • 265 Answers
SOURCE: car alarm wont turn off
Try changing the batterys in the remotes mate
Posted on Feb 16, 2009
  • 412 Answers
SOURCE: 2005 Chrysler Grand Voyager. Central locking
the body control module may need a software update..check with your local dealer
Posted on Jun 12, 2009
  • 31 Answers
SOURCE: kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
Posted on Sep 17, 2009
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
Mar 23, 2017 | 2000 Volkswagen Jetta TDI
Tip
How to get a Viper alarm out of valet mode
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
on Apr 14, 2010 | Vehicle Parts & Accessories
Tip
How to get a Viper alarm into valet mode
Entering Valet Mode with Key Fob:
Entering Valet Mode with Valet Button:
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
Alarm worked fine then 3clicks from the "brain"
Your system is in valet mode. Depending on the brand and model, the procedure to turn off valet mode will differ. It can be as simple as flipping the switch or pressing a button. Or require a more complex set of steps that may involve the ignition switch and a combination of presses of the valet switch.
May 05, 2011 | Vehicle Parts & Accessories
I need some help on my old Clifford Alarm system. I purchased my Toyota used about a year ago and I can not get the light on the dash to go off. I replaced the batteries in the key ring on both sets but it...
it is unlikely that the light is causing the battery to drain. it sounds like the system is in valet mode, if it's an older Clifford with a two button keypad somewhere (typically on the dash), turn ignition on, and press the * button twice, then press and hold the blank button.
if it's a newer Clifford system (Clifford Matrix), locate the valet button, then turn the key to ignition (ON), then off and press and release the valet button.
Mar 01, 2011 | Toyota Vehicle Parts & Accessories
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but...
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Mar 01, 2009 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
432 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
