Question about Janome Memory Craft 9500 Computerized Sewing Machine
Lost face plate screw where can I order a replacement?
    Problem Solver:
  • 17 Answers
Just visit us at www.janomestuff.com
Posted on Sep 24, 2009
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
I have a 6212C Singer sewing machine and I removed the plate that holds the bulb in place and somehow cannot replace it properly to where the face fits on.
Download your user manual free from Singer and go to Page 66. You might find it useful. Another question -- is the new bulb exactly the same size as the old bulb?
Sep 30, 2015 | Singer Sewing Machines
How to remove the bulb fro my jamone J3 18
  • Power off - unplug
    • Allow bulb to cool a few minutes
  • Left side of machine
  • With small screw driver, carefully Pry off/Remove the cap and the screw. Remove the face plate.
    Keep the 3 parts to replace = Cap, Screw, Face plate
    Push and turn the bulb counterclockwise to remove the bulb.
    Push and turn the bulb clockwise to reinsert new Light bulb
Apr 19, 2015 | Janome Sewing Machines
Why does my bobbin thread tangle around my bobbin plate
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top
Jun 10, 2012 | Brother Sewing Machines
Hello, I need to replace my light bulb. How do I remove the face plate?
the face plate either has hinges at the back so you gently pull on it to open
or there is a plug with a hidden screw,,carefully use a screw driver to get the plug out & then remove the screw & take off the door & change the bulb
Nov 23, 2010 | Janome 6019QC Mechanical Sewing Machine
Where do you oil this machine -- it's not in the owner's manual.
Welcome to FixYa! on the list below is the steps to oil your sewing machine.
  1. Remove the screw from the top of the Janome face plate with a small flathead screwdriver. The face plate is on the top of the sewing machine directly above the needle.
  2. Pull the face plate up and away from the sewing machine gently.
  3. Face the sewing machine as if you were about to start sewing.
  4. Locate a small cylinder attached to the side of the sewing machine facing you that had been covered by the face plate. Apply one or two drops of oil to the top of this cylinder.
  5. Locate a small square that is directly above the needle of the machine, also previous hidden by the face plate. Apply one or two drops of oil directly above and below this square.
  6. Replace the face plate and tighten the screw.
  7. Open the hook cover of the sewing machine as if you were changing the bobbin. This area is located directly under the needle.
  8. Remove the bobbin case by grasping the lever on the case and gently pulling the case out from the machine.
  9. Remove the hook ring and the hook. These two parts are behind the bobbin case and should come out easily.
  10. Apply one drop of oil to the center of the hole the bobbin was removed from.
  11. Replace all of the parts you removed from the sewing machine.
Good luck
Nov 09, 2010 | Janome 4052LX Mechanical Sewing Machine
Need to change light bulb
some machines it's called the lamp cover door --these machine have a hinge at the back, carefully pull the door toward the back of the machine & it should open to show the bulb
some machines call it the face plate--there is a hidden screw under a plastic plug, gently pry the plug with a screw driver & then take the screw out, & remove the plate & the bulb should be easy to replace,just put the plate back on after changing the bulb & replace the screw & plug
happy sewing
Sep 30, 2010 | Husqvarna Huskystar 207 Sewing Machine
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
HOw do I change the light bulb?
on the left hand side of the sewing machine is the lamp cover door( face plate)
some have a hinge on the back & they just pull open
others have a hidden screw(there a tab you have to remove with a screw driver) then just unscrew the screw & take off the face plate & change the bulb
don't loose the tab or the screw
Aug 31, 2010 | Kenmore 11101 Mechanical Sewing Machine
A pin got caught in the foot of my Pfaff 2048 and now the needle hits the face plate. I tried changing the needle, but no help.
the face plate may have been dislodged, check the screw, try taking it off and putting it back on. if it continues, it may be damaged and need to be replaced
Oct 18, 2009 | Kenmore 15218 Mechanical Sewing Machine
Janome Memory Craft 9500 Computerized Sewing Machine Logo
70 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
