Question about Magic Chef 31000 Gas Kitchen Range
BAKE OVEN WONT GO ON THE EGNITER DOSE BUT DOSENT GO ON TO BAKE
WHY WHEN I TURN ON THE OVEN TO BAKE DONT WORK IT EGNITER GOSE ON BUT DOSENT CACH ON FIRE THE GAS BAR AND THE BROIL DOSE WORK BUT NOT THE BAKE
  • 5,911 Answers
If you are having problems with the bake feature not lighting or taking longer than usual to ignite, you may have an oven igniter going bad. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The gas for both oven manifolds is fed through the same source. Barring a problem with the oven control board, you more than likely have an ignitor on the bake manifold failing or has become weak. The bake feature tends to fail more often due to the frequency of use.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Posted on Jun 26, 2009
How do I bake a store bought frozen pie in my proline convection oven ?
2 Easy Ways to Cook a Frozen Pie - wikiHow
https://www.wikihow.com/Cook-a-Frozen-Pie
  1. Cached
Rating: 64% - ‎28 votes Baking a frozen pie can be simple-open the box, toss the pie in the oven, and ... I baked a store-bought frozen pie in my new oven in the regular bake mode. Missing: proline
Baking Directions - Willamette Valley Pie Company
https://www.wvpie.com/products/baking-directions/
  1. Cached
  2. Similar
DO NOT DEFROST, keep this pie frozen until you're ready to bake it. ... If the crust becomes darker than you think it should be, cover it with foil for the last ... Convection oven: Bake for 80 to 85 minutes at 330 degrees F. Ovens may vary. ... Our Product Line · Buy in Your Area · Fundraisers · Baking Directions · Pie Ingredients ... Missing: proline
How to get pie crust to brown on the bottom - Flourish - King Arthur Flour
https://blog.kingarthurflour.com/2017/.../how-to-get-pie-crust-to-brown-on-the-botto...
  1. Cached
Nov 13, 2017 - KitchenAid Pro Line Mixer ... Getting a brown, flaky/crispy bottom crust on your pie is all about ... Placing them on the oven's middle rack to bake resulted in pie with ... And you can keep using it - so long as you place it on your oven's .... For a two crust apple pie convection bake would work, but I would ...
43 best Eat Convection Oven Recipes images on Pinterest ' Cooking ...
https://www.pinterest.com/candijjj/eat-convection-oven-recipes/
  1. Similar
See more ideas about Cooking recipes, Toaster ovens and Convection oven recipes. ... Bring the oil to a boil for a quick and easy dessert recipe for chocolate ...... Toaster Oven Recipes - Prepare Chicken Pot Pie in a Toaster Oven! .... Tip: If you can& find microwavable ravioli, use one bag to 16 ounces) frozen ravioli.
32 best Toaster Oven Treats images on Pinterest ' Toaster oven ...
https://www.pinterest.com/blackanddecker/toaster-oven-treats/
  1. Similar
See more ideas about Toaster oven recipes, Toaster ovens and Convection oven recipes ... Homemade Toaster Strudels - these are SO much better than the store bought kind... ...... Toaster Oven Mini-Pies are easy to make and absolutely yummy! ..... Oven toasted Ravioli using frozen ravioli, sounds like a yummy appetizer ...
May 24, 2018 | Ovens
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Kenmore oven wont work
Hi, The most common issue when the oven doesn't work is the ignitor. You can open the door and remove the floor panel inside the oven. Start the bake and see if the ignotor glows. It probibly will but, that doesn't mean it is ok. It just means the ignitor is getting voltage. When the ignitor is glowing, you can try (BE CAREFULL not to be to close to the buner) and tap on the side of the gas valve with the handle of a screwdriver. If the gas ignites, you will need to change that ignitor.
Again, this is very common.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 11, 2009 | Kenmore 33169 Gas Single Oven
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Overn will not work properly
sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Apr 05, 2008 | Ovens
Oven
open the oven door take the panel off the inside bottom. turn your oven on bake if you see a red glow coming from the ignitor coil and the oven burner is not lighting you need to have the ignitor coil replace. I don't know what make your oven is so this solutoun may or may not work.
Dec 21, 2007 | Ovens
Magic Chef 31000 Gas Kitchen Range Logo
277 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
