Question about Garmin eTrex Venture Cx GPS Receiver
How to reformat a corrupted microsd (with no sd card reader)
While uploading my first set of maps, I realized that at that speed, my bateries would die before the end of the process. So I interrupted the transfer in a clean way it seemed.
However, from that point, the HCX won't boot with that card in.
I press On. Stays on boot screen as long as i push. But as soon as I release the button, it goes off in a dirty way, with visual effects that looks like those described by others : persistence + one strange horizontal line sometimes and somewhere randomly.
Then How can I reformat it ? (I have no microsd card reader !)
To format, it seems you need to go in the menus ....
Isn't there a sequence of key pressures to do that on bootup ?
  • Anonymous Aug 09, 2008
    my micro SD is not working?
  • Garmin Master
  • 638 Answers
Take the card to almost any computer store and ask them to format it FAT32.
While your unit is connected to your PC via USB cable, it is NOT using the batteries, it is using the power from your PC. Just tell it to transfer the maps and then leave it alone until it is finished. A lot of maps will take a long time to knit together, and then transfer.
Hope this helps.
Posted on Apr 10, 2008
How to remove write-protection on a micro sd card
  1. Connect the microSD card to a computer
    Use a memory card reader to connect the microSD card to a computer for formatting. In case you're using an SD card adapter, ensure that the write protection key is in the unlock position.
  2. Locate the card Right-click My Computer, and click Manage. Go to the Disk Management tab on the left pane, and locate your microSD card from the list of available disks.
  3. Format the microSD card Right-click on the microSD card's drive, and click Format. This eliminates all data, including corrupted files that cause write protection in storage devices
Nov 09, 2016 | Electronics - Others
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
My micro sd card reader is unallocated
Unallocated means the SD card has either
a. Never been formatted (highly unlikely)
b. Corrupted and lost it's format.
You can format it again with the default settings.
Wiki link guide for PC or Mac here >> How to Format an SD Card
Fat32 is a good choice for Phones, PC data and images.
Mar 20, 2014 | IOGear USB 3.0 Secure Digital/microSD Card...
Ok so i turned on my GPS(navigon 2110 max) and out of nothing this is the message I got "image file corrupted, update cancelled" i tried the fac reset but that didnt work, I pressed and hold the...
Do you get a different result if you turn on the unit with the SD card not installed? If so, then you may be able to solve the problem by installing an SD card with a known good program and map file(s). In that case, obtain an SD card reader for your computer if you do not have one. If your computer can read the SD card, make a backup image of it, then install a file set on it.
If the cannot be read, then you will need to reformat it and restore the original map files or try to install a new map image file to it.
In you are unable to install good application and map files on the SD card, you may have to get a new SD card from Navigon.
Dec 01, 2011 | GPS
My Sandisk 2GB micro SD card will not re-format and hence remove corrupted files using the Windows format tool. Plus files will not delete at all, and just reappear!!! Is the card gone for good?
To be honest, once you're getting this kind of problem, the card can no longer use. You need to buy a new card.
However, I would suggest to try different things first:
1. If you're trying to reformat the card using the SD adapter or card reader, you may want to try to use different adapter or different card reader.
2. You may try different computer as well.
If the same problem occur, then there's no other option but to buy a new one.
Thank you and good luck!
Nov 07, 2010 | SanDisk 2GB microSD Memory Card
I put my SD card in but nothing happens. I've double checked that the card contains picture files using a 24 in 1 USB Card Reader. I'm using a Kingston microSD with adapter. When I take the SD card out of...
Check the way the SD card was formatted. FAT16 or FAT32. Save the images out to the computer, Reformat the SD card to FAT32, add the images. If that doesn't work, do the same with FAT16.
Dec 17, 2017 | Matsunichi 8 digital picture frame
How can i reformat my sd memory card? while it has a password that i forgot
On a PC with SD card slot, an SD card is handled pretty much the same way as any removable media. External SD card reader/writer devices with USB connectivity come for 10-20 US$.
Make sure the little slider on the side of the SD is not set to "write protect" and you format it just like a floppy disk (Windows: right click on the media icon, and select "Format").
Feb 09, 2010 | SanDisk 2GB microSD Memory Card
Memory card on my navigon 8100t one month old got corrupted when tri to downlod new map can i get a new one
Reformat it FAT32 using a SD card reader. Let me know if it worked. Email me at kazi at hotmail dot com.
Oct 06, 2009 | GPS
Garmin eTrex Venture Cx GPS Receiver Logo
1,501 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
