Tv worked fine, left room came back no power. Depressed power button nothing. Read owners manual. said to unplug wait 30 seconds and then plug back in. A visual indication from back of set showed some componets lit, then a click and the powwer lite came on, then went off and all the lites on chasis were also off. Set is a Hitachi Projection tv, about 10 years old but has had limited use. We are senior citizens and do not watch a lot of TV. Model number of this set is 50UX58K....my junior years I was an electronic technician in the Air Force and have had experience working with this type of componet. One of the first to work on solid state. Michael
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 61 Answers
SOURCE: RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Posted on Mar 07, 2008
  • 927 Answers
Good Day, you all;
The front panel light on Hitachi TV does not really tell you much. To see what the TV is doing or better said NOT doing is remove back from the set.
If you are not a technical type person, it would be better to consult an authorized service center, but if you are perform this; 1. Remove back
2. Observe led and notice which once light, there are as many as 9 LED's.
Now that will tell you what area of the TV's circuits are to be concerned about.
Let me know, Good Luck, big IRISH.
Posted on Aug 06, 2008
SOURCE: Hitachi 50UX58K-V8F001238
our hitachi did the same thing. It cost us 300.00 to tell us that there were two bad solder joints and they caused a power surge or something.
Posted on Aug 12, 2008
  • 668 Answers
SOURCE: hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Posted on Jun 30, 2009
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
Apr 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
No Power at All
check electromaniac.com and download a service manual for your tv set good luck
Jan 23, 2009 | Insignia NS-30HTV 30" TV
My 32" sharp lcd doesn't respond to the remote
Ok I just dealt with the Sharp customer support for this problem. 1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
... let me tell you I thought the lady was crazy when she was telling me this but it worked!
Dec 19, 2008 | Sharp LC-32SB24U 32 in. LCD TV
NO POWER
I ended up unplugging both sides of the power cord (from the TV and the wall), waiting five seconds, plugged it back it, and it worked fine.
Sep 11, 2008 | Televison & Video
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
