Question about Canon PowerShot S2 IS Digital Camera
Newly charged batteries don't work
Newly charged batteries don't take more than 10 pictures before the charge battery light comes one; yet the playback works. Have tried a different charger and different batteries; same story. I have a Canon Powershot S2 IS.
  • 34 Answers
Try going to canon.com and download the firmware update for your camer, it will work fine after that
Posted on Jun 26, 2009
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Built-in flash not working
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Apr 03, 2017 | Nikon D60 Digital Camera with 18-55mm lens
I have a Moto v3x y charge it 10 hours the first time HELP ME
Well ,thanksa lot for your quicky answer
I solved the problem...the battery was in bad conditions ,so they changed it
Regards
darycel
Nov 18, 2008 | Motorola Mobility RAZR V3x Cellular Phone
My psp will only turn on for about 10 seconds and turn off there is no picture during that time what do i do
It sounds like a problem with your rechargeable battery. when you charge it, is it showing a full charge -- should be after around 45 minutes. wosrt case is you'll need a replacement battery from Sony.
Apr 11, 2008 | Sony PlayStation Portable (PSP) Console
Batteries won't stay chargedds - even new batteries and newly charged batteries
sir,ur camera age 4 years, this problum is common becouse ur camera flash unit capacitors drained, use 2200mha batterys u get some good results
Mar 23, 2008 | Canon PowerShot A80 Digital Camera
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Battery charging
I was charging newly purchase camera for hours, then I realized my battery was in upside-down. It took approx 2 hours to fully charge once I fixed the battery install!
Dec 03, 2007 | Jazz DV-179 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
178 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
