Question about Biostar P4M800-M7A Motherboard
Intermittent Reboots pc is only a couple years old no real problems except for now it reboots whenever it feels like it.  Is this a BIOS problem it has two gigs of ram and is the 3.0 GHz processor model.
    Problem Solver:
  • 14 Answers
I would first remove some RAM to see if the problem persists. It's an easy beginning to get your problem resolved.
Posted on Nov 05, 2007
Acer Aspire M5630 Series Original Desktop Motherboard Eg31m reboots
hey there, i know that problem u need to apply a new bios u can find it here : m5630
Nov 23, 2013 | Acer Aspire M5630 Series Original Desktop...
My AMD computer started rebooting on its own minutes into a boot. I tried reinstalling a fresh copy of XP but it would reboot into the installation. It reboots in the BIOS setup so it is not the O/S. It...
this is a mobo setting try reseting the board using the bios jumper switch it to the reset possition turn on pc /switch off pc and replace to original setting see if this helps b4 replacing board
Jan 01, 2010 | Computers & Internet
Computer doesn't boot after a couple of reboots
Have you checked the backup battery to the Bios. You should have one that charges when its on and one that is more like a large watch battery that keeps the Bios memory when no power is available. If these are not the problem, then you may have to do a Bios flash from a disk from manufacturers web site.
If you have no power at all, then double check power supply with voltmeter.
Aug 12, 2009 | Gigabyte GA-8IPE1000MK Motherboard
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
Dell Dimension 2350 reboots every 3 secs
Could be a couple of things.
Disconnect the C drive and see if the computer will stay turned on. If it does (you'll get an operating system not found error), then reconnect the c drive and see if you can get into the BIOS. If not, you'll need to replace the hard drive.
Could also be a faulty power supply. As soon as it tries to boot off the hard drive, it puts too much strain on the PS and causes a reboot.
Finally, if neither of those fix the issue, then the problem is motherboard and at that point it is more cost effective to replace the computer unless you can find a cheap, used motherboard. Good luck!
Jul 05, 2009 | Dell Computers & Internet
My wifes hp dv9000 laptop will boot up and go to the desktop, 30 sec. later it shuts off, then reboots. It started doing this after we used a hp recovery disk. Her computer crashed on her overnight and hp...
You will need to do more trouble shooting. If you can, boot into safe mode and see if system reboots. If it does boot into the bios and see if it reboots there.
If system reboots in all modes then you have a hardware problem and will need to be serviced. However if it does not reboot in the bios then there is a good chance that some part of your windows system is corrupted.
If you find this helpful please rate so.
Thanks
May 06, 2009 | HP Pavilion dv9000t Notebook
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Reboots
The problem has to be with the ram contacts being dirty. Detach your ram and clean the contact leads with an eraser.It should clear the problem.
have u recently made any changes in your hardware configurations?
if yes, reset it to the previous state(remove any hardware you recently added)
hopes this will help you. feel free to notify.
Dec 03, 2008 | E-Machines eMachines Desktop PC
Battery drains rapidly, clock settings lost, frequent reboots
I would fit a new battery as it is more than 5 years old.
Jun 10, 2017 | Dell Axim X51v Pocket PC
SYSTEM REBOOTS AFTER SHUTTING DOWN
It seems that when you formatted, you took your Bios settings with it. The latest bios can be obtained from toshibas website....Below is a direct link to the bios.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1976812xml&sliceId=&dialogID=51709196&stateId=0%200%2051707515
Sep 24, 2008 | Toshiba Satellite A215-S7422 Notebook
Biostar P4M800-M7A Motherboard Logo
60 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
