Question about Miele S558 Red Velvet Bagged Canister Vacuum
No power to my miele s558? - Miele S558 Red Velvet Bagged Canister Vacuum
    Welcome Back:
    Visited the website for 2 consecutive days.
It's a bad model that's why they took it off the market. Mine is doing the same thing have taken it in twice for the same reason. First time they replaced the cord $200.00 which I did not believe it was the problem. A year and a half later still cutting off on me as if it's over heating I took it in and they found nothing. Took it home and it did it again within 5 minutes of using it, new bag inside suction was fine. Can't explain why this has happened since I have owned this vacuume. A LEMON! pilmammy@gmail.com
Posted on Aug 11, 2010
5 Suggested Answers
  • 97 Answers
SOURCE: miele s558 Silver Moon
It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Posted on Mar 07, 2009
  • 8404 Answers
SOURCE: warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Posted on Sep 23, 2009
  • 10 Answers
SOURCE: I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
Posted on May 13, 2010
  • 97 Answers
SOURCE: miele silver moon s558 powers up sometimes not
That's remarkably good news. You can almost certainly fix it for about twenty cents in about twenty minutes. First, open the main bag chamber, and remove the upper bag chamber lid. This can be achieved by gently prying back the tabs back by the hinges, and then sliding the whole thing upward. Next, you'll want to remove the exhaust filter and the two screws holding the control unit to the back of the vacuum. (The black part.) Lift up at the front of the control unit and it should lift away. This may make a terrifying snapping noise, don't worry about it. You didn't break it! Next you'll need to remove the screws that hold the main chassis onto the base. I believe there are roughly seven, in a perimeter around the chassis, if memory serves. Note that there are a couple up by the handle part. Once they're all removed, the whole thing should lift right off. Now, here's the actual cause of your problem. Over time, the cord reels in these guys start to wear out a little bit, and what happens is that the electrical contacts that keep power flowing through your reel start to move apart from each other. Locate the cord reel, which should be hanging out in the base area. Grab the white reel itself and wiggle it left and right. See all that play? So here's the fix: get a ziptie from an auto parts store or any place like that. Remove the screw holding the cord reel assembly into the machine and lift out the cord reel. When looking at the reel, you should be able to see the electrical leads that come out of the center of the wheel: one black, one white. On the OPPOSITE side of the reel from those wires, you're going to want to put the ziptie around that central axle. This will then take out all that slack you were feeling. Make sure you clip the end of the ziptie before you re-install your reel. Place the cord reel back in the body and then make sure you re-thread the cord through the hole in the back of the chassis. Place the chassis back on, replace the screws. Place the control unit back on, and replace the screws, snap the chassis lid back in, replace your bag and filter, and you should be in business. Please note that this works 99% of the time, but occasionally a reel will wear out to the point where this fix won't work. If it does, you do now know how to install it, so you shouldn't have to pay anyone else to do it for you. A new reel costs about $120, which is why I ALWAYS tried this fix first. Also of note: I wrote these instructions from memory, so if you're trucking along and you find that I've missed something somewhere, post another clarification request and I'll walk you through it. Good luck! -R
Posted on Sep 29, 2011
Miele silver moon vac model s558 serial number nr57365268 what year?
I think it was made in 2008, I found a phone number 1-800-221-8227, maybe they can confirm
Aug 23, 2014 | Miele s558 Silver Moon Vacuum
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
I have a Miele silver moon that kept shutting off while using it. I replaced the hose with the new 125-s model but problem came back. It does appear to be a problem with the hose. Any suggestions?
My S558 Red Velvet had the same problem. I disassembled the handle and cleaned the rings and electrical contacts. The problem has not come back.
Sep 28, 2010 | Miele s558 Silver Moon Vacuum
return it
May 11, 2010 | Miele s558 Silver Moon Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Greetings from GoVacuum,
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
Le s558 s'arrete sans raison meme apres verification des filtres sac, etc
maybe the fiter it not place properly, there it'a a safety switch that it's not activated
Jan 06, 2010 | Miele S558 Red Velvet Bagged Canister...
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Warning light on, vacuum will not turn on
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
Miele S558 Red Velvet Bagged Canister Vacuum Logo
585 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
