Question about 2wire (1000-000057-000) Modem
Can I conect a 2wire modem my neighbor is giving me mine suddenly stop working
  • 80 Answers
If you have the disc that comes with it then you should have no problems. The disc will calibrate the modem to work for the IP address that your internet provider gave you.
Posted on Jun 26, 2009
How do I boost the signal from an at&t 2wire dsl modem so that the signal will work better in some parts of the house.
for wireless signal 1st thing to consider is the EMI's (eletro-magnetic interference) anything that is near that modem that produces static electricity, radio frequency and magnetic energy (eg. cordless phone, speaker, anything electronic...) isolate the modem at-least 6 feet away from this said EMI's.
2nd you may check on the the wirelss settings on your modem's GUI(interface) see the link:http://support.2wire.com/index.php?page=view&article=60
wireless channel and power settings and the only once you should change... channel such as 1,6,7 are sometimes used by other device (wireless phone, neighbor's router) power settings: as you place it on a higher number it gives longer distance but gets thinner space(area)
consider the red signals as you place the power higher the signal gets longer but thiner.
lastly wireless doesnt penetrate walls/ glasses it only bounce back and forth to it... so less wall or interference the better chance of going directly to the access point...
if you really havea big house try consider buying wireless booster/repeater...
Sep 02, 2011 | 2wire (1000-400108-001) Router
I use an AT&T 2Wire 2701HG-B Gateway Modem and whenever I use the laptop wireless option, the modem tends to repeatedly reset itself, affecting internet use both on the laptop and a home computer which...
http://www.fixya.com/support/t4987959-att_2wire_wireless_router_keeps
Here is a solution I posted today for a similar issue. Might fix your problem.
Jan 13, 2011 | Computers & Internet
I can't get my computer to conect to my 2wire modem. how do i do it
you are going to have to use the driver cd that came with the modem also is this your first time hooking up there are instructions in the quick start guide that tells you where to find the drivers on the cd. i know because i use a 2wire modem i can help you, but if you just follow the guide you will be up and running.
Mar 24, 2010 | 2wire Computers & Internet
I have a 2 wire AT&T modem. The modem power
Try to replace the power cord with a same voltage adapter from Radio Shack or any local electronic store. If you search FixYa using key work "2Wire Modem", you'll see a whole bunch of people having the exactly same problem with their 2Wire modems! I fixed mine (all three of them) by simply replacing the power cords!
Nov 22, 2009 | 2wire (1000-000057-000) Modem
The modem works great until the phone rings. I am
check the splitter and make sure your phone is connected to "phone" and internet is connected to "DSL or DATA. our neighbor has the same problem and when i checked the splitter, the phone is connected to "data" port.
Nov 04, 2009 | 2wire (1000-000057-000) Modem
2wire stopped working, is there another modem brand i could use
You can use modem from Actiontech or Speedstream they can be use as a replacement for your old 2wire modem.....
Oct 30, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire password
If it is yours then the network password will be printed on the side of the wireless modem/router. If it is your neighbors then your outta luck unless they give you the password.
May 09, 2009 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
2Wire connecting to my PS3
change the encryption type from WPSK 2 to WEP and choose custom connection on your PS3.
Just fill in the details manually this should work. The PS3 does support WPSK and WPSK 2 but mine had the same problem. and it fixed mine. And before you go doing that just check that you havn't got MAC filtering turned on because that will stop it recieving an IP
Sep 03, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
2WIRE Single Port DSL Line Filter
i think when you purchased the 2wire modem it usually comes along with 3 sets of single port dsl line filters, try out those other filters see which one works. if the local network light doesn't come on, (are you using 2wire 1000 series?), check the network adapters in your computer, this usually happens when you are using lower versions of OS. try the power outlet in the kitchen / bathroom, if power light doesn't come on, push the reset button for 30 secs. if power light is still off or red, then you may need to replace the modem (check if it's still under warranty, if not you will need to buy a new one.) also you should be using the same power adapter that came with the modem, check the specs. sometimes if the modem is more or less than 3 years old, they could get defective especially if it's often affected by sudden power surges.
Jan 29, 2008 | 2wire Single Port DSL Line Filter (21869)
2wire (1000-000057-000) Modem Logo
128 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
