Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000 flashing yellow light
When power button is pushed the cpu unit will not boot up. The power button flashes yellow.
  • Dell Master
  • 2,404 Answers
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Posted on Jun 26, 2009
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Dimension would not Boot when I try to Boot the power light jush flashes if I remove the yellow and black cable from the power surploy you can here it booting but there is no video
hi there,
well,unplug your pc, try to put back cable supply,try to configure your hardisk on cmos/bios set up,if the hardisk have detected by your cpu,refresh your hardisk,disconnect hardisk ide cable from motherboard and put it back.then try to run again.if windows does not
come out,reinstall your windows again on your cd installer you can fix from repair your system.have a nice day
Jul 06, 2009 | Dell Dimension 1100 PC Desktop
Power button flashes yellow and will not power up.
Try a different know good working power supply and only hook up the main power connector to the motherboard as well as the p4 connector. If you get power then you know that the original power supply is bad.
If you try another known good working power supply and you get the same yellow light then the motherboard is bad and would need to be replaced.
Jun 27, 2009 | Dell Dimension 3000 PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
Mar 19, 2009 | Dell Dimension 8200 PC Desktop
Dell deminsion 3000, fans run, hard drive light on, no boot up.
Very possibly you can unhook the hard drive and cd dvd drivers then boot system see if it goes to post try and get to setup if that does not work then you system board problems or cpu problems.
Mar 16, 2009 | Dell Dimension 3000 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 3000 PC Desktop Logo
725 people viewed this question
Alun Cox
