Question about Philips Televison & Video
Slightly out of focus
The picture has been perfect until a few days ago. The picture has gone slightly out of focus, shows this way on everthing including OSD. I am an electronic tech. but have mainly worked on audio products.
Any help would be much appreciated.
Thanks,
Ben
    Sniper:
  • 56 Answers
Try crt base replacement, and adjust focus controll on FBT
Posted on Jul 19, 2009
How to adjut the carb
This is tricky because it's one of those hands on things to show & hear. Most homeowners get this wrong and either the saw runs to rich or too lean(real danger). On the high speed jet, you turn it IN until the saw seems to scream uncontrollably(just for a few secs!) and then back the screw out until it starts to 'four stoke'....which means its cutting out slightly. On the low speed jet, you adjust right at the point where blipping the throttle trigger gives you fastest response. But if turning IN the low speed jet is raising your idle significantly, then you've gone too far.
If you've got the high speed jet set correctly, it will four stoke until you bury the bar and then smooth out perfectly under load.
Jun 18, 2013 | Poulan 16in. 35 Cc Chainsaw 952802144
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Sharp TV slightly out of focus
so not focus on out side please focus on write side http://specialneedsplanning.net/
Mar 18, 2013 | Televison & Video
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
Apr 12, 2009 | Canon PowerShot S3 IS Digital Camera
Revving after a complete stop
MAY BE CAMSHAFT POSITION SENSOR, TORQUE CONVERTER CLUTCH CIRCUIT, WEAK TRANNY WHICH FORD IS KNOWN FOR, THROTTLE POSITION SENSOR, OR BAD TORQUE CONVERTER. DO YOU HAVE ANY "CHECK ENGINE" LIGHTS ON? IF YOU DO THAN IT IS AN ELECTRICAL OR SENSOR PROBLEM. IF NOT THAN IT IS A PROBLEM WITH THE TRANNY PARTS, TORQUE CONVERTER, OR LINKAGE PROBLEM
Mar 31, 2009 | 1996 Ford Taurus
96 Ford Taurus GL Revving problem when stop then go
Did you check the transmission fluid again. You could have a major leak. Or reving the car up so high it started to burn the clutches in your transmission, resulting in replacing the transmission. Always check the fluid. A few dollars for fluid is better than 1500 bucks for a new tranny
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
RCA Televsion Stopped Working
its gone. electrical smell, like burnt? thats how we electricitions check for problems in the field. :) means something overheated or shorted. Easy way of telling, no tools required.
Oct 16, 2007 | RCA F35755MB 35" TV
Televison & Video Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
