Question about GoVideo Go Video DVD/VCR Combo
Sonic/blue go.video dvr4400
No sound on vcr or when viewing the tv through the vcr unit. The dvd player
works fine with sound. I've hit any and every button that might have to do with the player. I unpluged the unit overnight thinking it might reset itself. I tried to call the numbers listed in the book and neither of them works any longer. Please help.
  • Anonymous Nov 22, 2007
    Setup does not display on my TV. How can I be assured that the unit is set to channel 3
  • robyn234 Oct 13, 2008
    No sound on VCR or when viewing the tv through the vcr unit. The DVD player works fine with sound. I've hit any and every button that might have to do with the player.
    Please help.
    Sergeant:
  • 182 Answers
Same thing with mine, I think the tape head is bad. I tried adjusting the azimuth and still have no sound on VCR Mine also has an issue if I push on the yellow component RCA too hard it will short out with the sound RCA and I can hear the video noise through my left channel sound. If I pull it out just a tiny bit it will stop. But that's a problem due to something that smacked into the RCA Plug stack. Mine was like that when I got it (used). I resoldered the pins back onto the board since they were all broken loose. i thought that was the problem but now I think it was bad and someone got sick of messing with it and smashed or kicked it before they got rid of it.
I'm not going to mess with it anymore, I'm going to try another audio pickup head from a working machine and see if that's what the problem is. VCRs are a buck at thrift stores just pick one up for the head if its bad. look for a sony or similar brand I've seen some sony's that were identical to go video's guts, same boards and DVD players different outputs and front covers. They have 2 models that are supported by the same boards. they have a check mark on the go-video for model 4300 and sony uses the model 4400 I think but the only difference is the extra outputs on the sony. The chassis and covers were identical also. Just a different piece of plastic surrounding the output section to accommodate the extra connections. If you have no service skills then just sell it for the DVD player to someone who might be able to fix it. It will cost more than it's worth to fix
Posted on Jan 19, 2016
Trash it !!
Posted on Nov 28, 2010
  • joeshow Nov 28, 2010
    Unless you want to pay for the new circuit board. I will get a new model not a combo!!
DVD works but not VCR
There seems to be a compatability issue, run an rca video and audio cables from the output of the vcr to the input of the tv, that should restore the video and sound.
Mar 11, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Emerson ewc1303 tv/vcr combo...can I also hook up a dvd?
USER MANUAL
Viewing the user manual above, the only inputs are on the front of the unit. (1) video - yellow
and (1) Audio - White
You can watch the DVD, but it will only have MONO sound.
Connect component RCA cable RED YELLOW WHITE (minus red in your case) to the front of the unit.
To view from that source, Change the channel to 2 then hit the down arrow one more time to get in AUX mode.
Jan 21, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
Manual for dvr4400
are ppl still buying govideo ..i heard its a piece of shit?
Jan 26, 2008 | GoVideo Go Video DVD/VCR Combo
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
GoVideo Go Video DVD/VCR Combo Logo
556 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
