Question about Toshiba Tecra 8000 Notebook
When booting up it says invalid system disk, what do I do?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the BIOS and make sure its recognizing the hard drive. if it is then reset the defaults in the BIOS and reboot and see what happens.
Pls reinstall operating system(windows).
Posted on Jun 26, 2009
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Invalid system disk
The computer TRIED and FAILED to boot from the hard-disk, and now is expecting you to insert a "bootable" CD-ROM into the optical drive. Replace the "dead" hard-disk.
Dec 01, 2013 | Compaq Computers & Internet
Need to reboot computer,windows98,invalid disk error
You have to go into your BIOS and select booting from Disk not hard drive when i say disk i mean either the cdrom or dvd disk players attached to your motherboard. also you can get a boot disk to try that at the link below.
http://www.allbootdisks.com/download/98.html
Apr 07, 2012 | Computers & Internet
At boot-up I get "invalid
1) Go into your bios by pressing the Delete key.
2) Navigate to boot disk priority.
3) Set this to Primary master disk drive (The drive that your operating system is installed on.
4) The save and exit.
This should stop the message from coming up and solve your problem.
Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
Thanks.
Nov 01, 2010 | ASUS A7V333 Motherboard
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Toshiba Tecra 8000 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
