Question about RCA G32750AT TV
Speakers I NEED TWO SPEAKERS FOR MY T.V. CAN NOT FIND THE SPEAKERS.
  • 54 Answers
Just about any speakers should work fine. They would sound best if pair of same model.
If it has a headphone jack, just plug in a pair of powered computer speakers (the usual kind). Spend a little more and get a subwoofer and better sound all around. Figure $10 to $100 per set.
Posted on Jun 26, 2009
How do I get power
Older passive computer speakers do not need a power supply.
Modern active speakers might use batteries but mostly need a power supply that plugs into the mains power outlet and provides the right voltage, current and polarity the speakers need.
Some low-powered active speakers simply plug into the computer usb.
Oct 05, 2015 | Audio Players & Recorders
I just plugged Logitech speakers into my desktop. Do I need to download software for them to work?
no make sure the volume is up on the new speakers if so keep the speakers plugged in and reboot the system
Sep 24, 2012 | Packard Bell Speaker Computer Speakers
Need the speaker diagram wiring for a 97 chevy tahoe
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 01, 2018 | Car Audio & Video
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
Installation of speakers
The speakers require the AC adapter to be connected for the speakers to function. The AC adapter powers the amplifier of the speakers
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
Apr 18, 2010 | Dell A215 Computer Speakers
Have a dell computer with acer plug in speakers which are not playing or showing as being connected, don't have a disk for the speakers is there somewhere i can download the information i need, speakers...
Try connecting the speakers to a different computer, to see if the speakers work at all.
It's 100% "normal" for the speakers to *NOT* be "detected" by the computer -- the speakers simply are _NOT_ a "plug-and-play" device; there are just "dumb" electro-mechanical units.
There _never_ is a need for a "disk" for speakers;
you never need instructions on how to use a pencil, either. :-)
Apr 04, 2010 | Acer (90.18612.36B) Computer Speakers
I need to know how to hokk up speakers with it
Hooking up a speakers to the monitor depends on the connections that you have.
1. What type of speakers do you have? Is it a regular computer speakers (2-channeled or multimedia)?
2. Does it have a 3.5mm jack or an RCA jack?
3. Does the monitor has a speaker ports?
If the monitor doesn't have a speaker ports were you can connect you speakers, then it's not possible. Meaning that you could only connect the speakers to the computer.
Aug 04, 2009 | NEC Computers & Internet
No sound. Do I need driver software for these speakers?
shouldn't need it for speakers. you do however need one for the sound card on your computer. if the speakers were an upgrade and you know the sound card works... check that it is plugged into the proper hole at the back of the computer and that there is power to the speakers.
Robert
Aug 29, 2008 | Yamaha YST-MSW10 Computer Speakers
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
