Question about BenQ FP731 17" LCD Monitor
Black out problem
My Benq Fp731 appear blackout on the screen but, there's a led light on. No signal from cpu.
crdng
  • BenQ Master
  • 2,404 Answers
Try a different known working monitor and hook it up to the computer. Turn on the computer and the monitor and see if you can get video. If you get video then you know the original monitor is bad.
If with the known good working monitor you still don't get video then you know its something either with the video card or the motherboard if you have integrated video.
Posted on Jun 26, 2009
The led light is green when plugged but nothing shows up on the screen
check your VGA cable or onboard VGA card or try to replace if its not working on any 3d card
Jul 11, 2010 | BenQ FP731 17" LCD Monitor
Power led flashing on dell E172FPB monitor
The fact this is a LCd or at least listed as a LCD there are a few porbable causes to a faulure,
1. Bent pins
2. Bad signal cable
3. Bad back light (take a flash light point it at the screen if you see the screen change the backlight)
4. Bad signal board (rare)
please do be considerate and check these things in the list please to leace postive feedback and ratings for any expert that tried to help you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | BenQ FP731 17" LCD Monitor
Where can I find instructions on replacing the backlight on benq fp731?
jsiwiec, Are you absolutly certain that the "cold-cathode-fluorescent-lamps" need replacing, or if the "switch-mode-power-supply"/"CCFL inverter supply" is not working and is in shutdown mode? CCFL's are not some kind of miniature version of those energy efficient screw-in new style, curlie-Q cfl light bulbs you buy at the local home-center!!! In any case here are some places to checkout first. www.ccfldirect.com ,
www.teliostech.com , www.ccl-la.com/badcaps.htm , www.lcdparts.net, www.lcdrepair.us You do know that most times the problem is not the lamps. Did your LCD display have bright, crisp, colorful images displayed on the lcd panel 2- 3 days before black screen happened? How many TOTAL "ON" hours of use on this BenQ FP731 ? When was unit produced? Good luck with repair. Hope info was helpful.
12fixlouie
Mar 12, 2010 | BenQ FP731 - 17" LCD Monitor
Goes on for a second then blackout
the powersuply for your TL tube is shutting down.
you need to replace 3 elco electrical condensator in the powersupply 1*22/40V 2*470/25V after this the monitor will work fine
Feb 13, 2010 | BenQ FP731 17" LCD Monitor
My aoc lcd monitor appear full white screen
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display on the screen. A replacement of LCD panel might be the solution. regards
May 13, 2009 | BenQ FP731 17" LCD Monitor
Blackout on plug in!
Try your monitor on another computer or another monitor on your PC. This will tell you if the monitor has a problem or your video card (or connection).
Oct 30, 2008 | BenQ FP731 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Problem
Connect it to another device, if you get the same result the backlight is bad! These can be replaced, but can be costly!
Nov 14, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
822 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
