Sharp Aquos 40lcd will not play bluray
Sony Bluray connected to my Sharp Aquos 40 lcd through hdmi will not display video. Sign appears on screen that states "video signal incompatible. Check output signal device". It is a brand new sony Bluray that I had re-checked at the store and it works fine.
When I hook up my HDD dvd player through the same HDMI, no problem.
My LCD tv is 720dpi, would that be the problem?
  • garryatkins Jun 26, 2009
    Thanks, I will try this.
    Problem Solver:
  • 6 Answers
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Posted on Jun 26, 2009
Picture all blurred when playing bluray
Connect the blu-ray player into the HDMI port that currently has sky on it. Does it work then? if so the port you were using has failed. If not the blu ray player has failed.
Dec 28, 2013 | Sony Televison & Video
NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
CAN I USE HDMI CABLE TO PLAY MOVIE THROUGH DAV-DZ270 TO A LCD TV ?
Yes. This is what you should do. Connect the Bluray players HDMI cable directly to your TV, then use an optical cable (usually around $20-40) to go from the Bluray player to the surround system. You will then need to enter the menu of the Bluray player and set up the Audio to be run through the Optical output instead of the HDMI. Problem solved!
Jan 21, 2011 | Sony DAV-DZ100 System
Hello, I just purchased a 3D BD SONY BDP-S470 and i connect to an amplifier Yamaha RVX-3800 and this to a Sharp LCD LC-60LE925UN. When I play a 3D movie the BDP-S470 informs me that the movie can...
You need to run optical cable either from tv audio out or bluray audio out to Yamaha to get bluray surround sound, I'm afraid, there is no other choice/ option.
Thanks.
Jan 17, 2011 | Sony BDPS470 Bluray DVD Player (BDPS470)
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I have 2 ps3 consoles one new slim model other is older model both attached to 1080p 120hz tv's one sony one sharp aquos both using top of line $300 monster cable hdmi cables. The ps3 menu screen on both...
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
Televison & Video Logo
665 people viewed this question
Top Televison & Video Experts
