Question about Seagate Barracuda 7200.10 - 80GB - 7200rpm - 100MBps Ultra ATA/100 - Ultra ATA/10... 80 GB EIDE Hard Drive
Firmware update for Seagate Barracuda 7200 10 80 gb ultra ATA. I got problem due to firmware detection. the firmware on the Hard disk said it going with type 3.AAC, but when I try to open with Sea tool, it won't recognixed that type at all, it just shown ''...'' on my firmware revision
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Regards,
Angeliczone
Posted on Jun 27, 2009
Hi, I have some troubles with my Baracuda ATA IV 20gb,so I need to download some softwear for this harddrive.Do you know weare I can find it? Thanks Allex Bulat
Hi
Hard Drive faults can rarely be repaired by downlading drivers. The drivers for almost all hard drives are already in any operating system.
Most hard drive faults are physical faults, such as bad sectors, controller board faults or shock damage.
Some apparent faults may actually be due to incorrect jumper settings. It is worth fully exploring all the jumper setting options available on this drive.
This drive is quite an old ATA drive and because hard drives work so hard spinning several thousand times per minute (yours is 7,200rpm), the older a hard drive gets the more susceptible it is to failure.
Your drive was probably manufactured in 2001 and is likely to have had a 3 year warranty when new, so it is long past its warranty period. This means that little help is now available to you from Seagate.
It is sometimes possible to download Firware Updates for certain hard drives, which can improve the performance of the drive. But Firmware Updates rarely repair hard drive errors.
You can find detailed technical information about your hard drive here:
www.seagate.com/support/disc/manuals/ata/100129212b.pdf
Available Firmware Update Information for Seagate Drives can be found here:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931&NewLang=en To check if any Firmware Updates are available for your drive, you need the full model number, which should be somewhere on the label (possibly ST380021A).
If firmware updates or jumper settings changes don't work, you may have to consider buying a new ATA hard drive.
I hope this helps.
Aug 27, 2011 | Seagate Barracuda ATA IV (ST320011A) 20 GB...
I've been noticing a squeaking sound intermittently
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
Aug 16, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
I want to detect driver Thanks
There is _NO_ need for any additional device-driver -- Windows "natively" supports all disk-drives.
Dec 17, 2010 | Seagate Barracuda 7200.10 ST3160815A -...
I need the driver of my Seagate Barracuda 7200.7 80 Gbytes Ultra ATA Model: ST380011A Thanks
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
Nov 24, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate ST3160215A Hard Disk PCB Card Short-160 GB ATA
Hi sunny_2003,
There are many hard drive pcb supplier such as http://www.hddzone.com/seagate-pcb-c-1.html
Be sure to backup your data.
Mar 11, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Hard disk drive
try reading the hard disk drive myths....it may explain more.
http://www.techarp.com/showarticle.aspx?artno=84&pgno=1
Feb 04, 2009 | Seagate Barracuda 7200.10 - 250GB -...
What to do with unreadable but recognised hard disk segate 400GB
After data is recovered, it should be moved to another drive to keep safe. The drive that was recovered has to be reformatted and checked for errors before storing more data.
Nov 28, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate Barracuda 7200.10 - 80GB - 7200rpm - 100MBps Ultra ATA/100 - Ultra ATA/10... 80 GB EIDE Hard Drive Logo
1,965 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
