Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Interior lights will not turn off
My interior lights will not turn off. I've checked my rear lights and all are functioning. All doors are shut but will not turn off light.
  • 54 Answers
I assume you've checked the most often overlooked yet obvious dash switch/knob. Could be a defective door switch or wire shorted to ground (usually at a sharp metallic edge or a sharp screw penetrating the insulation); you may be able to find which one using an ohmmeter on lowest scale: disconnect negative terminal on car battery first, then remove all the bulbs affected, next hook the ohmmeter between ground and the one of the two wires going to one of the lights. The meter will read almost 0.00 ohms but not quite. (If it doesn't, try the other wire.) Now open each door, one by one. If you see any change that is repeatable, that door switch is working. If you come to a door that is not working, there will be no change and that is the one to replace and/or check the wiring to. Let me know if you need help at that point. BTW, ohmmeter is part of DMM digital multimeter selling for $6-20. Interior lights will not turn off - 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Posted on Jun 26, 2009
Where is the courtesy light switch in the drivers door on a 1998 Navigator
courtesy light switch , is door ajar switch an it's part of the door lock actuator . Light on coming on ? Not going off ? The ajar switch is a input to the GEM module , fords BCM - body control module . The GEM will energize a relay to turn on the lights .
The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
Mite be a good idea to have it check for DTC'S - diagnostic trouble codes .
B1322 Driver Door Ajar Circuit Short to Ground GEM GO to Pinpoint Test B . B1323 Door Ajar Lamp Circuit Failure GEM REFER to Section 413-01 . B1325 Door Ajar Lamp Circuit Short to Battery GEM REFER to Section 413-01 . B1330 Passenger Door Ajar Circuit Short to Ground GEM REFER to Section 417-02 . B1334 Decklid Ajar Rear Door Circuit Short to Ground GEM GO to Pinpoint Test C . B1338 Door Ajar RR Circuit Short to Ground
Mar 26, 2017 | 1998 Lincoln Navigator
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    • The ignition is in the RUN or START position and the interior lamp control is not activated.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Rear door lights and key lights won't shut off in my 1993 Cadillac sedan deville
    There is a light control module under the dashboard near the radio. It provides interior lighting delay and automatic interior light function. When this module fails, the back lights and key lights will remain on.
    Jul 17, 2014 | Cars & Trucks
    Interior lights stay on while driving and after the ignition is shut off.
    I would check your door jamb switches first, they are spring loaded and you can check them by pushing each one in and move your finger and they should pop back out without any restriction. When the springs are open your interior lights should come on and when pressed in turned off. Also be sure to check your console dimmer control/interior light switch as well to make sure it is functioning properly
    Mar 03, 2011 | 2005 Chrysler Town & Country
    How do you get the interior lights to come on when a door is open
    Hi, viewer. The interior light is powered and controlled by the body control module or BCM. However, there is an on/off button beside the main headlight switch that overrides the interior lighting function. If this button is off, interior lights will not come on regardless of any door being closed or opened.
    If this button is on, interior lights will come on whenever a door is opened. If you close all doors, and if the driver door is the last to be closed, the interior lights will stay on for about 30 sec and then the lights goes off automatically. In case you left any door opened too long, the BCM has an internal timer that will shut off the interior lights automatically when it detects that a door is still opened and the allowable time has elapsed. The BCM is programmed this way to protect the battery circuit and functions. : )
    Sep 13, 2010 | 2008 GMC Acadia
    2006 Hyundai Sonata, Doors do not turn on interior light
    Hi
    Make sure all door switches are functioning properly. See that each switch pushes in and out, without sticking.
    Feb 09, 2010 | 2006 Hyundai Sonata
    Interior lights in my 98 grand cherokee won't turn. No open door signal and it's not the rear dome light switch turned on.
    dimmer switch on the dash... lower it. it should click and should shut off the interior lights.
    Jan 04, 2010 | 1997 Jeep Grand Cherokee
    Dome light wont turn off
    some times the door switch can be faulty. and it may be coincidence that the interior switch is faulty too. i have owned alot of S- series trucks and a few of them have done this to me. you need to individually check each door for switch contact
    Jan 25, 2009 | 1994 Chevrolet S-10 Blazer
    Interior lights won't turn off 1999 BuicK LeSabre.
    yes there is a relay switch in engine compartment or under dash
    Jan 25, 2009 | 2001 Buick LeSabre
    MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
    106 people viewed this question
    Top MTX Car Audio & Video Experts
    hoyzee1
    Marvin
    Marvin
    RegWorts
    Level 1 Expert
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
