Question about Dyson Vacuums
Beater bar doesn't move - Dyson Vacuums
    Problem Solver:
  • 4 Answers
I smelled burning and thought I had burned up my belt...when I took the bottom off the belt was fine. I took the brush off and found that if you pull real hard the ends come off...OMG there was so much dirt, hair and **** that the brush was not moving freely...after I cleaned all of that out and put it back together...it's just like new...I can't believe it...I'm so happy.
Posted on Oct 31, 2010
    Problem Solver:
  • 11 Answers
Is the belt broken?
Posted on Jun 26, 2009
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Beater bar not working - no variable suction
Take it to your local vac shop for repair. Depending on what model you have, it may have a bad switch or you brushroll ends could have failed. Both are common issues.
Aug 08, 2017 | Dyson Vacuums
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
I have a dyson DC28 vacuum and the power button flashes on and off and the beater bar quit turning. I turned it over and found some string caught on the beater bar which I removed, but the beater bar still...
I had the same symptom with my wife's DC28. The problem was associated with the cam driven height adjustment mechanism. The beater bar must rock freely up and down when pressing on the tabs that the end cam lobes actuate. On ours I found hair and crud jammed in between the end of the beater bar and the side of the vacuum head preventing it from moving freely. To clean it out I fashioned a hook tool by straightening a paper clip and bending the tip at 90*, then took a flat screwdriver to pry the gap open a bit so I could use my tool to clean out the buildup.
I removed the plate that holds the cam in place (6 torx screws) to gain access to the rocker tabs, although in hind sight I could have probably just left it in place. It doesn't matter how you set the cam back into place. It's self aligning with the aid of the micro-switches inside.
Hope this helps
Mar 15, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
The beater bar doesn't move when you push the vacuum. If you lift the vacuum while it's running, it's going like crazy!
replace the belt, it is so stretched that it is slipping on the beater bar when it comes in contact with the carpet. it takes the 38528-040 belt. i think its 5 screws on the bottom to gain access to beater bar and belt.
Jan 05, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
DC07 beater bar does not move
this is a common problem it moves on air flow, the air flow may be good but there is stuff wrapped around the ends of the beater bar, disassemble bottom of the unit and clean real good. it comes apart real easy :)
Oct 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
My Oreck beater bar is not turning. The bar is free of hair or strings, the motor is working, just the bar will not move
If the motor is working then check the drive belt. There's a door on the right hand side of the Oreck that comes off with a cross head screw. Check the drive belt isn't broken. If its intact then its a possibility that the beater bar has seized up - beater bars from Oreck are available although you should check EBay to see if you can get a cheaper part. Sounds like a drive belt problem though.
Mar 05, 2009 | Oreck XL2600 Vacuum
Vacuums Logo
139 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
