Question about HP Pavilion a420n PC Desktop
Light yellow under blue on light. power and fans on.
What can I do?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Change out the hard drive, sounds like its having trouble running. Put in a known good working hard drive and see if the constant yellow light goes away.
    Problem Solver:
  • 18 Answers
Just unplug first the ac cable after 20 seconds pluin and test again. or it the same problem just open your cpu ang pull out the memory and clean the surface and insert again test your cpu again
Posted on Jun 26, 2009
Pull cord switch in bathroom has red, blue, yellow wires, I've wired yellow to earth, red to com and blue to L2 - not working, why?
Is this switched used for a fan and a light or for a two speed fan??? Most switches do not have neutral or what you term ground going through them. I can only guess that the blue wire connects to the power in, and the red and yellow wires go to two different cuircuts, such as a fan and a light or to a two speed fan.
Nov 10, 2013 | Electrical Supplies
Fan noise and blinking blue power light
green=power in motherboard.
blue=stand by.
yellow=memory powerd
Jun 13, 2013 | Gateway GT5622 PC Desktop
How can i get the words to which fuse operates what part of the car in an 06 charger???
Hi, All the Info You Need Is Detailed Below:
Front Power Distribution Center Fuses
# Amp Description
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
1 60 Clear Ignition Off Draw
2 40 Green Battery
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
Sep 13, 2012 | Cars & Trucks
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Jun 30, 2009 | Dryers
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
HP Pavilion a420n PC Desktop Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
