Power light blinks
TV was on most of the afternoon, turned it off by the remote and went to dinner. After returning, turned the TV back on, it clicked like normal, notice the OPC and power lights lit and constant, audio came on for about 10 seconds, audio stopped and it clicked and the power light blinks ... tried it a second time, same thing happened, tried a third time and the TV would not even click. Unplugged the unit for at least 5 minutes, with the same results, just a blinking power light ...
HELP ... !!!
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
alpug
  • 1961 Answers
SOURCE: TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Posted on Jun 04, 2010
budmrtn
  • 11361 Answers
SOURCE: Power blinking green light
Power supply section may be the problem, that will be the first place to look, look for caps with leaking/bulging tops, see examples of failed TV and monitors due to bad caps here;
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
SOURCE: Flashing OPC/DL light
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and power lights on the front of the tv should turn green and blue, respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the inverter circuit, and the inverter switches on the back light for the tv. The mosfet at location Q723 was suspect when I tested it, so I went ahead and replaced it and the other three mosfets "chained" to it as preventative maintenance. Parts can be bought from digikey.com - digikey is usually a same-day shipper with the best prices, so I use them. USPS Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear 100-watt light bulb - Home Depot sells the sockets. Alternatively, you can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws holding the back cover on. You can either mark the screw locations and bag the screws or do what I did: Unscrew the screws, leaving them in their holes, then slowly lift the back cover off and carefully set it down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic below), which is the board where the AC power cable connects. Carefully detach the connectors that connect to the other boards in the tv from the power supply, then remove the screws that hold the power supply to the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710, and C852 without touching them (they look like soda cans). Flip over the power supply board. Touch each wire of the socketed light bulb or resistor for about 3 seconds to the negative and positive leads of each large capacitor, respectively; polarity is irrelevant. This discharges the high voltage from the capacitors so you don't get shocked while working on the power supply. The voltage usually slowly dissipates on its own, but it's better to be safe than sorry when you're talking about a potentially lethal 450V. Check the voltage with your multimeter in the appropriate DC mode to verify that the capacitor voltage has been drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks like a small black box) has indeed failed by holding the multimeter's red and black probes on the fuse's leads with the multimeter in continuity mode. If you have no continuity, the fuse has internally failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple screws to hold it in for now. Reattach the connectors to the power supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it into the wall socket). Hold down "Input" and "Volume-Down" simultaneously, then plug in the tv. The tv picture and sound should come on.
(11) With a small screwdriver or other probing device, depress the Reset button, not the System Reset button; it's the last recessed button below the cable jack on the back of the tv. The tv will reset, then you should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
Posted on Dec 30, 2010
Tv went out itself red light ( power on off ) just blink, we can't turn on tv set neither fron remote or at the tv set
Jun 30, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
Aug 28, 2010 | One For All URC-3021 Remote Control
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black screen sound ok
Have you tried unplugging the power for a few seconds and plugging it back in?
Aug 28, 2008 | Proscan 19LA25Q 19 in. LCD Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
