Question about Brother MFC-9420CN All-In-One Laser Printer
Very bad paper curling when printing a number of sheet. Have tried various brands and weights of paper
  • 41 Answers
Most likely problem is moisture in the paper.Where do you store it.
Posted on Jun 26, 2009
Paper printing hot and curling on kyocera taskalfa 300i.....how do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Sticking paper
Do not use recycled paper in this machine if you can. I would also try to fan the **** of paper before installing it in the machine.
Aug 02, 2010 | Lexmark Office Equipment & Supplies
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper is curled inwards when it is ejected from the printer.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 20, 2009 | HP Office Equipment & Supplies
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Media curls on lead and trailing edges
Any of the following:-
Ensure the correct paper weight settings are in use. Excesive heat will cause paper curl.
Feed paper short edge first.
This is normal with high ink coverage on light paper. Use a heavier weight paper.
Your fuser may need replacing.
Jun 02, 2008 | Xerox Phaser 7750DN Laser Printer
Why is the printer grabbing more than one sheet at a time?
this is caused due to the pickup rollers and seperation pads being worn. if you run your fingers across them you will no dobt find that they are very smooth and thats the problem. the rollers and pads need to be rough so that they can cause friction against eachother to seperate the pages. i
What make model is it and i will try source the part numbers for you
Hope this helps
Pete
Pete@wedotoners.com
Oct 03, 2007 | Lexmark T632 Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
194 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
