Question about Casio G-Shock GW300CA-1V Wrist Watch
There is no sound on my casio g shock after getting the battery and seals replaced. All other functions are fine. Thank you Gurus
SOURCE: Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
Posted on Jul 09, 2008
escapement
  • 2334 Answers
SOURCE: what watch battery do i need?
If you are asking for that, it means you want to replace battery yourself, and if you do, you will have to open your watch anyway. So, open it, take the battery out and memorise all the writings on the battery. This is the type of battery you need.
Do not forget to rate, please.
If I was wrong with my guess, then submit all the writings on your watch caseback and dial, please....and do not rate yet.
Posted on Feb 28, 2009
  • 183 Answers
SOURCE: Sound not working for any alarms after replacing
The sound board is the touchiest part of watches with sound. This can be subject to all sorts of problems during battery replacement. You can sometimes get all the functions back by "AC"ing the watch but in many cases once it is fried it will have to be replaced.
To have an "AC" or reset performed you should see a watch maker or technician specializing in watch repair.
Posted on Sep 17, 2009
SOURCE: Casio G-Shock
You've got to get the little spring in the back to touch the metal part of the back of the watch for the sound to work! I had the same problem and now it works fine, soo happy!!!
Posted on Apr 22, 2010
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
My g-shock watch model# DW 5700 displays a rectangular nox in the upper right corner with the letters "REM" below it. I've installed a new battery and this is all I get. None of the function buttons...
Rem is the reminder function of the watch , you can turn it off and on by holding down the bottom right button usually on casio watches. You can also find the online manual here http://world.casio.com/wat/download/en/manual/
please rate solution
Oct 18, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio g-shock protection model blank face after new battery installed by a jeweler
What kind of battery did they put in it?? G shocks are powered by a rechargeable solar battery!!! Should not have been replaced unless it was the same type of battery. I would be going back to jeweler and asking them to send your watch to Casio and they pay for the new solar battery. Let me know what happens.
Aug 19, 2010 | Casio G-Shock 800D 7V watch
Have a casio g-shock GS-300. Need to turn off the hourly signal (the beep). Grateful for solution
I have a Casio GS-300 watch. I need to change the batteries, but cannot figure out how to get the back off. Do you have any ideas as to how I can do this.
Thank you Vanessa
Jun 11, 2010 | Casio Watches
I have a Casio Shock Risist watch (GW-500A) that says "charge" on the display, that is all it shows. Does it need a new battery or what?
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
Nov 24, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock
Check out this YouTube video.
Feb 19, 2008 | Watches
Casio 2654 mtg 901
sounds like it might not be getting enough sunlight. If it has the solar cell in it tape it to the inside of your window for a weekend. If it doesn't charge up the battery enough to make that bar quit flashing then you may need to have the battery changed.
Jan 02, 2007 | Casio G-Shock MTG900DA-8V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
186 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
