Question about Frigidaire Freezers
Frigidaire gallery ultraice model no.frs26xgcw ices up on front of ice pan only. the other part of the freezer stays frost free and food does not ice but front of ice pan ices so bad its hard to open door.
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
  • 6 Answers
SOURCE: frost free freezer with ice in the bottom and
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Posted on Jul 11, 2009
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
How to defrost
If this is an automatic defrost or "no-frost" freezer and it has developed a lot of frost and ice, call a repairman. That should never happen.
But if it's a manual defrost model, follow this procedure.
1. Turn off the freezer. Then remove all the food and toss it into a picnic cooler to keep it frozen. (Some blue ice packs will help.)
2. Open the drain on the bottom of the freezer, and put the end of the hose from the drain (which most have) into a roasting pan to catch the water from the melted frost.
3. Leave the door open. If you have a small electric space heater, blow warm air into the freezer to speed up the melting process.
4. Don't scrape the ice -- you could puncture a cooling coil in some units, making the freezer useless.
5. In about 30 or 40 minutes (15 with the space heater) the ice will be melted.
6. Dry the interior with a towel, toss the food back in, turn the freezer on again, and you're done.
Jun 02, 2015 | Frost Freezers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
No drain plug in freezer to drain water out when defrosting?
The drain hole is behind the back wall underneath the evaporator coil. Im guessing you have ice on the freezer floor. This is because the drain tubing from the freezer to the drain pan underneath is clogged. There will likely be ice that will need to be defrosted in the drain tubing in order to get to the clog. Once the ice is removed, I use compressed air when I perform this refrigerator repair service.
Sep 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
342 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
