Question about RCA Televison & Video
The infored sensor on my tv doesnt seem to pick up anthing?
  • 5 more comments
  • alacranci146 Jun 26, 2009
    is there a code to a universal remote master code I can use please help
    and is there a dishnetwork master code as well
    can we chat please to explain the problem in detail
    rca 20F510TD
    can we chat
    the batteries are fine thats not the problem
    infored thing is'nt working I guess ill return the tv to the store
    rca 20F510TD infored wont pick up the universal remote codes or dish network remote codes and the batteries are new
  • RCA Master
  • 3,866 Answers
Cleaing or replacing this sensor will shore this up, sometimes the lens gets dirty or blocked by debris /dust or other typrs of matter. If simply cleaning the lens does not work the sensor insdie will need to be replaced.
Also trying another remote, making sure the remote batteries are fresh/new to R/O sensor malfuction this would be adviseable.
Thanks for using Fixay I hope these tips help you
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
  • 520 Answers
Hi ...couple of questions...is your remote fairly large silver in color and sort of an oblong hour glass design...secondly ,do you know your tv model?
  • Jeff Barton
    Jeff Barton Jun 26, 2009
    sorry ...computer prob...i'm back sorry for the delay ...chat OK
    President:
  • 1,734 Answers
Change the batteries in your remote control. Wait for at least 5 minutes before you insert the new ones.
    Sergeant:
  • 326 Answers
This is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut must be replaced
  • SABARI ANAND
    SABARI ANAND Jun 26, 2009
    no u cant use like that
Brake lights staying on
Did you check the brake fluid level? You may have either a bad ring gear which the sensor picks up the signal from - or a bad sensor for the ABS - I'd pull each wheel and inspect for missing teeth on the gear the sensor reads off off - and look for bad wires on a sensor - perhaps one is not gapped right.
Seek service manual for propper gapping on the sensor to the ring gear. Worst case scenario - ABS accumulator/pump could be faulty. Be advised that whils this ABS light is alluminated - the ABS is not activated - you are on BASE brakes only and most likely your traction control (ESP or TCS) is disabled as well.
I highly doubt it's going to be anthing more then a wheel speed sensor or indicator (ring gear). Disconnect your cables battery to reset the ECU for 5 minutes, then plug it back in, that'll clear whatever codes you have, if the error returns... then you should really look into it.
Hope this helps.
Sep 04, 2011 | Plymouth Acclaim Cars & Trucks
ABS warning light stays on
Hope this helps.
Sep 04, 2011 | 1994 Saab 900
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
89 SC STARTS AND RUN GOOD ABOUT 5 MIN THEN STUMBLES AND PINGS AND DOESNT PICK UP SPEED FUEL PRESURE IS FINE BUT SEEMS BE TO LEAN
make sure oxygen sensors are good, also check injectors,make sure fuelpreasure is up to specs, and last check your mass air flow sensor, they go bad very often or get very dirty.try cleaning first but i would replace it if it is dirty, sometime you can get lucky and clean but sometimes not, good luck.
Oct 22, 2009 | 1993 Ford Thunderbird
I am Trying to find out what all the dash light sensors mean. under the rpm one is on and i dont know the meaning of is. it is next to the one that shows like sensor of the back of the van
http://www.genuineservice.com/genuineservice/en/default?page=genuineService
go to this site and pick owner guide on left task bar. Input your vehicle infor then pick get owner guide. Then pick the owner guide and instrument cluster info for freestar begins on page 10
Apr 03, 2009 | 2005 Ford Freestar
Laptop doesnt display anything
if there is no display whn u press the start button then your motherboard is screwed. i had this problem with mine too. I got it replaced fro free as it had a warranty... anthing more contact babu_aero@yahoo.com
Jul 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Blue shadows in pic.
glycol leak....bad stuff....conductive and corrosive. the blue tube might have to be replaced along with anthing that it has leaked on.. just depends on if which seals have failed
Mar 13, 2008 | RCA D52130 52" Rear Projection Television
Remote sensor
Do you have the original remote?
Feb 17, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
