Question about NetGear WGR614 Wireless Router
Computer is not pick up signal from router - NetGear WGR614 Wireless Router
  • 854 Answers
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Posted on Jun 26, 2009
Wireless light is on but get no signal
Have you tried with another computer to isolate the issue, weather its from the router or the computer.
If same problem persists with another computer, maybe the router is set not to broadcast the SSID.
Feb 28, 2012 | Computers & Internet
I have got a new modem, now router will not pick up signal- i was told told contact you about getting ???something?? to resend a signal or picking up the signal again? NEED HELP
Who makes your router? if it's a belkin you may have to switch your modem to bridge. If not plug the cable from the modem to your computerif you can make to the internet replug it in to the router and restart the router and then restart your computer see if you can get to the internet again. If not call your isp and go through the correct setup for your equipment. good luck
Feb 05, 2011 | Computers & Internet
If i hook my router up too the at&t computer box with my main pc.will my downstairs pc pick up the wireless signal?
yes if it a wireless computer then it will pick up the signl.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have just set up my computer with wireless internet. My laptop picked up the signal with no problem. I have purchased an wireless adaptor of the x-box 360 but am unable to connect to the internet. It...
On the setup for your wireless network through your router, you have to allow access for other devices. Your internet provider should also be able to walk you through this process as they did for me when I had the exact same problem.
Jan 01, 2010 | Microsoft Xbox Console
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
PC had problem with VGA signal after a wireless router was instal
There's no way the router would affect the VGA signal. You might have just accidentally trip the VGA cable on the back of your computer causing a loose connection. Just unplug and replug the VGA cable then reboot your computer.
Nov 21, 2008 | Computers & Internet
Cant get wirless lap top pick up router
I know it sounds stupid but a lot of people just forget to turn on the wireless switch.
You may want to check first if the router is being picked up by other computers just to eliminate the possibility of a busted router. If no other computers can pick up your Router's signal then it's the router that you need to replace. If other computers can pick up your router's signal, then it's the computer's wireless card that's busted.
Sep 19, 2008 | Belkin Computers & Internet
Wireless router signal
evidently you computer is picking up a weak signal.
1. you may have a defective router.
2 the pickup on your computer may be weak or defective
3 I would try to reinstall the program for the router and dtv
Lou Margolis
Allied Electronics
alliedtv@verizon.net
or call me 513 490 0759
Aug 14, 2008 | NetGear WGT624 Wireless Router
Reconfigure router
Changing settings on your computer does not affect your router, but since the other computers cannot pick up the signal, then there is something wrong here.. See if there is a reset button on the Motorola and press it for 30 seconds to see if the router resets to its original configuration. If not, then you need to hardwire your computer to the router and get into the config page. usually, to do this, you just open up a browser and in the address line, type in the Default Gateway Address (usually this is 192.168.1.1).
To find the DG for your LAN:
Start > Run > cmd (ok)
From the Command Shell type:
ipconfig /all > ip.txt
notepad ip.txt
This should open a window with all your IP information in it. you will find a line called Default Gateway.. this is the address (probably 192.168.x.x) that you put in your Browser Window Address Line to access the configuration page of the router..
Dec 04, 2007 | Arris SURFboard SBG900 Wireless Router...
NetGear WGR614 Wireless Router Logo
258 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
