The resistance can only be adjusted up and stays that way, even if unplugged then replugged. Cannot be adjusted down. When I adjust the resistance, I can hear movement of the cables. The instant I pull on the cables (to work out), the display goes right back to 10 which is the minimum; but the actual resistance stays the same. As you might imagine, there is no way for me to tell what the actual resistance on my machine is right now since the display is inaccurate. Also, being a tiny young woman - the resistance is stuck too high for me to do any workouts, rendering the machine practically useless. Please help me, guys. I'd really appreciate any troubleshooting and/or parts replacement suggestions. Thanks in advance.
SOURCE: Calypso wash motion washing machine FL code stuck
jesus crist and you post all that information just like that..waooooh
SOURCE: Weider Platinum Crossbow is locked up.
i have the manual, to recalibrate the machine press and hold the next button and the motorized wieght adjustment+ button for five seconds. when the buttons are released, a number will appear in the reps display. press the next button again, then press the motorized weight adjustment+ button: this should start the reclaibration process. i am lucky i bought the machine in 10-2004 and it has a ten year warrenty. it isn't working it happened before and they had to replace the motor. if it works remembe to unplug the machine when not in use. it is a great machine to get in shape with. you just have to use it.
SOURCE: Weider Platinum Workout Poster
I couldn't find one online either so I had mine scanned and uploaded
http://www.mediafire.com/?5dzm31drljz
Enjoy!
SOURCE: need workout sheet for weider pro 4300
Hello. Contact Weider directly and tell them what you need. go to this link for the contact info, phone numbers, email etc.
https://www.iconservice.com/CustomerService/contactUs.do
please rate this answer as very helpful. thanks. J.
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Testimonial: "Thank you. We will work on that and see what happens. "
