Question about Golden Technologies Companion II Travel Scooter
Moving problem it wont go forward but will go backwards if you turn the speed control almost all the way down.its a golden companion 3 wheel scooter
  • 32 Answers
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Posted on Jul 12, 2009
Tilt steering stuck in down position.wont tilt forward.
I am sure you have tried this but put it all the way down and let it lock. Then try and pull it back up. The problem will be if it stays stuck. I would wiggle the wheel at the same time. May need a third hand to help.
Feb 23, 2015 | Golden Technologies Golden CompanioN II -...
Tilt column stuck in down position.wont tilt forward
The cable for the release lever might be stretched or broken. You have to get the tiller cover off to access it.
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
It sounds to me like someone has gotten inside & tampered with it, Cameron. Maybe they twisted the drive belt 180 degrees or something? Or rewired the motor backwards?
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
The scotter has like a 5 second delay when you push the forward control, then it takes off doing a wheelie, it bucks like a wild bull
Usually, the scooter has a small delay built into the controller for safety. This is so a person who may have a handicap or a tremor in their hand has more reaction time to make sure the scooter is going int he direction they need it to go. However, the acceleration should be gradual and should not lurch forward causing the front wheel to leave the ground.
Before turning on the scooter, make sure that the speed control is on the lowest setting. Make sure that you are sitting upright and that nothing is pulling on the rear of the scooter which can throw it off balance. Ensure that your weight is within the rider limits of the scooter. Check the tread on all of the tires to make sure they can get good grip on the surface you are riding on.
If you continue to have problems, contact the sales office where you purchased the scooter or the manufacturer for service as there may be a motor problem.
Oct 19, 2010 | Golden Technologies Golden CompanioN II -...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Reversing thumb controls
Your authorized Golden Technologies, Inc. dealer can reverse the thumb lever controls so that when you push on the “left” lever, your scooter will move in the forward direction, and pushing on the “right” lever will move your scooter in reverse.
If you don't want to go to a dealer, any mechanic who is willing can make this adjustment for y ou. hope this helps.
Feb 14, 2009 | Golden Technologies Companion II Travel...
Golden Technologies Companion II Travel Scooter Logo
372 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
