Question about Dell Dimension 4700 PC Desktop
I have the same problem 6 beeps...I green 3 yellow lights
Beep..pause...beep beep beep...pause..beep beep.
A is green...BCD are amber...what is the problem?
Dell Dimension 4700
  • lrfowler Jun 26, 2009
    The memory is out of the PC..I even removed the battery
    President:
  • 948 Answers
That beep code indicates memory is not being properly identified or used. Try removing memory and testing with one module at a time until you find the one module or slot that is causing the trouble.
Posted on Jun 26, 2009
  • Dick
    Dick Jun 26, 2009
    If you were getting the exact same beep code before you removed all the memory, add one module at a time and test again. Try all the slots available. If you get the same code with every module in all slots either you have the wrong memory or your motherboard is bad.
  • 555 Answers
My friend try to remove the memory of you computer and using a eraser of your pencil kindly rub the memory particularly the area where you usually plug in the memory slot. Rub it for 30 seconds then try to insert it back  to the memory slot then turn your computer on. If the problem is same and no progress then try to check the connection of your hard drive if it is properly connected and turn it on again. if the problem is still the same then find another memory that supports your computer and try to insert it in your computer and test it. If it works then the problem is your memory  or if its not then try to find computer technician and let the technician fix your problem. But i am sure that the memory is the cause of this error beep.
Hope this solution helps answer your problem. if you need more assistance just reply to this post. And if you find this solution able to answer your problem please rate it.
Thanks
I have 2 amber / yellow and 2 green lights on can you help please
Well, I\'ll go with Dick\'s solution. Its the Problem in your Ram or motherboard\'s ram slot. Check One by one both the ram and the slots.
May 05, 2014 | Dell Dimension 8200 PC Desktop
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Dell Inspiron 518 Solid Amber light on power button. My power went out today and i turned my computers back on and this happend. All fans are running.
Your computer has failed the Power On Self Test.
Be sure to check all external connections as well as the connections within the computer chassis. Clean the Gold fingered connections of the RAM modules and Graphics card with tissue paper.
Also go through my published guide entitled, My Computer is not turning on!!! Is it dead!!! No POST!!! for additional help and information.
You may need to clear the BIOS/CMOS.
Take care!
damnor01
Sep 22, 2011 | Dell Inspiron 518 Desktop Computer
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
My pc started beeping when i turned it on the other day... two beeps then a 1-2 second pause then beeps again .... i opened the case and took out the reset the ram but now the blue light on the pc is...
Katie Dell website and find the error codes for that model, that should tell you if it is a memory problem or what. Remember search for your model.
Sep 11, 2010 | Dell I531S-2809 PC Desktop
As i switch the ps3 on it beeps to come on and then it beeps to flash amber then switches itself to red. It has been an ongoing problem
PS3 amber light flashes with beeps means your PS3 had hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such amber light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
My computer is beeping at me during startup, and will not go past the load screen.... dell b110
The POWER LED on the front of the tower should be solid Green, If Solid Amber or Flashing Amber, there is either a power or MB problem. On the back of the tower are 4 LEDs the when posting normally are all Green. If YYGG for example, then you have a memory failure. More information can be found at support.dell.com using the no post troubleshooter
Sep 24, 2009 | Dell Dimension™ B110 PC Desktop
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
Dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 4700 PC Desktop Logo
516 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
