Question about Dell 924 All-in-One InkJet Printer
Connect dell printer 924
States computer not connected
SOURCE:
  • 1003 Answers
SOURCE: Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Posted on Jan 07, 2008
SOURCE: Scanner won't work on Dell 924
Same thing happened to me, only different model.
First, make sure you have the right drivers (and by that I mean 32-bit or 64-bit).
Go to control panel and remove your previous installation; reboot; reload the drivers with your All-In-One UNPLUGGED until they tell you to plug it in.
That was the trick that worked for me. Good Luck.
Posted on Aug 31, 2008
damanpreet_c
  • 69 Answers
SOURCE: dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
  • 514 Answers
SOURCE: Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Posted on Feb 28, 2009
ohms
  • 1879 Answers
SOURCE: Mac Compatible problem with Dell 924 Printer
no mac driver for that printer
Posted on Apr 14, 2009
I have a dell 924 printer and I cannot seem to find the right port for it. can you help me?
The system will assign the port. You can download the driver and manual for the 924 at
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
To connect the printer, connect the printer and computer using a USB cable, download and install the driver, turn on the printer. The system should sense the printer and install it so it can be used. Let me know if this solves the problem. Thanks.
Jul 19, 2010 | Dell 924 All-in-One InkJet Printer
How do i connect my dell aio 924 printer to my computer i do not have the starter disc and i need step by step setup instructions
Click here
Click on above link and download driver and patch update then install in computer.
then connect your printer with usb cable to computer then you can use it.
Let me know if you need further assistance.
Thanks for using FixYa.
May 23, 2010 | Dell 924 All-in-One InkJet Printer
Trying to connect printer to computer
and the trouble is what?
Is this printer on the Microsoft Hardware Compatibility list for your computer/operating system? Do you have the latest software? Are you properly connected?
www.dell.com/support
http://www.microsoft.com/windows/compatibility/en-us/default.aspx
May 01, 2010 | Dell 924 All-in-One InkJet Printer
How to connect to the mac computer
All computers need drivers for each device to work correctly with a computer. This DELL printer has a specific model printer drivers that work with PCs and laptops for Windows XP or Vista or Windows 7, but I do not think if there is a printer driver for the MAC.
You need to contact DELL or their WEB site for this problem.
Try this link :-
www.dell.com
Dec 24, 2009 | Dell 924 All-in-One InkJet Printer
Dell all in one printer 924 won't withwindows 7
Hi
Thanks for using FixYa. This Printer is not compatible with Windows 7 and therefore it is not printing while connected to HP computer.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Dell 924 All-in-One InkJet Printer
Dell photo ai0 924 what type of cord do I use to
You would need a standard USB printer cable to connect your printer to your computer. It is readily available at any radio shack near you. Refer to the following image to see how the ports at the cable would look like:
Thanks,
Abhishek
Sep 25, 2009 | Dell 924 All-in-One InkJet Printer
My Dell 924 printer is printing blank pages
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 fax
Hi ,
The 924 printer which you have is not a standalone faxing printer, in order to send or receive the faxes the printer should be connected to the computer and the phoneline should be connected to the internal modem of the computer and you will be able to send the faxes by scanning the document from the printer, you will find a software called ALL IN ONE CENTER installed on your computer , open the All in one center and then click on FAX Now and you will be able to send a fax.
Mar 29, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
