Blower motor Can I buy a 1/4hp blower motor for a rheem unit the blower bearings are shot it wont turn it bearly spins
  • 400 Answers
Yes you can!!
Posted on Jul 02, 2009
I have Rheem Pvw50, 50 gallon water heater installed at home. For the past few days, there is a noise coming out of blower motor. What could be the reason?
Your water heat is at an age that I would recommend replacing the whole unit. That one cannot be too efficient and most likely has sediment built up on the bottom of it pretty bad.
Jan 25, 2016 | Rheem Water Heaters
Why is blower motor making whining noise when on?
The bearings are shot. You have to replace it.
Nov 12, 2013 | 2002 Honda Accord
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
My ac blower does not work I tried the heat but the blower still does not work
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 18, 2009 | Heating & Cooling
Freezin ge airconditioner small window unit boughr 2008
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are, they need to be cleaned, if not, then you are probably low on refrigerant or Blower not running at full speed.
Aug 17, 2009 | Heating & Cooling
When the unit turns on the fan doesn't rotate and the air doesn't get cool
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
The blower on our unit works intermitently, so the AC is only cooling part of the time.
Aug 16, 2009 | Heating & Cooling
Unit turns on but it does not blow out any cooled air or any air at all. you can see that the drum inside that usually turns is not turning.
Aug 10, 2009 | Kenmore 72055 Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
Air handler squeals
Squealing sounds from a forced-air heat pump generally occur when the belt that connects the motor to the fan slips. If the blower is making a grinding noise, shut off the unit and call a heat pump repair technician --the motor's bearings are probably shot. In most cases, the belt is improperly aligned or worn and needs replacement. Follow the instructions in your owner?s manual (if you don?t have one, contact the manufacturer and ask for one). This job involves removing the access panel, loosening a couple of bolts that hold the blower motor at the proper tension, and realigning or adjusting the belt. In many cases, it?s a good idea to remove it and buy a replacement at the hardware store. When reinstalling the belt, be careful not to over-tighten it--this can wear out the motor bearings.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
