Kenmore 62622 Microwave Oven Logo
A
Anonymous Posted on Jun 10, 2014
The plate does not move, why
The fan and light works,but why the plate does not move
Ronald Rissel
Level 3:
Master:
  • Kenmore Master 715 Answers
  • Posted on Jan 25, 2015
Ronald Rissel
Kenmore Master
Level 3:
Master:
Answers
715
Questions
Helped
259057
Points
1075
Is there a turntable button on your control console? If so, press it! If not, then you probably have a bad turntable motor or else a bad (broken) shaft coupler.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Both oven lights blown and fan not working
If you've noticed that your oven is not heating up, there could be a problem with your oven fan thermostat.
its simple to check :
1.
Open oven door and locate the back plate, which can be found at the rear
of the appliance. Remove the back plate from the oven fan (it should be held in place by between two and six screws). The oven fan is located behind the back plate.
2.
Examine the oven fan element and the fan blades (they are exposed once the back plate has been removed). If there are noticeable signs of burning, blowing, bulging or splitting in an area of the oven fan, you can tell where the problem is coming from. It is also common for there to be no visible signs of a problem. This allows you to determine whether or not the oven fan can be replaced from inside, or if it is necessary to enter the back of the appliance.
3.
Remove screws from element and disconnect wires if screw heads are showing. This is commonly the case, as it is unusual to have to further disassemble the oven. After the screws are removed, the element becomes detached from the oven. Use caution to not accidentally pull out electrical wires that are connected to the element.
4.
Take the rear cover off, which is held in place by multiple screws. After that, you should be able to see the wiring harness, fan motor and the components of oven fan element. Parts of the fan element are near the round fan motor, which is located at the center of the oven. There are two electrical connections and one earth wire. Take note of the location that the earth wire is placed, because it needs to be restored to the same position.
5.
Remove the oven fan element. Check the element again for obvious signs of damage. If there are no apparent markings, check the oven with an electrical test meter or a continuity tester. After replacing oven fan element, return all connections and covers to their original positions.
This should help you up to an extent to check it in case of any assistance please revert back.
23helpful
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Not cooking, everything else works
Probably the door switch ...
Instructions can be found on this site.
If you really cant find them, let me know, OK?
a
1helpful
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
No heating
there is a relay on front panel this sends voltage to mwave needs to be replaced or dryjointed open front panel and check for little boxes on front panel those are relays
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
