Question about HP 2133 Notebook PC
I HAVE A MINI 10 DELL BUT I CANT SEEM TO GET THE WIRELESS STARTED TO START USING MY LAPTOP
  • 24 Answers
To turn on wireless, with the computer
turned on:
1. Press <Fn><F2> or press the key on the
keyboard.
The Wireless Enable/Disable dialog box
appears.
2. Select one of the following:
––Enable Bluetooth
––Enable Wireless LAN
3. Click OK.
To turn off wireless, press <Fn><F2> again to
turn off all radios.
-Dell mini User Guide Page 9-
Posted on Jun 26, 2009
Dell Inspiron Mini won't connect to wireless- won't ask for wireless password and therefore cannot connect. Help!
Learn easy Steps To Set-Up A New Dell Inspiron mini. If you need assistance with issue, Call immediately -18002044427 Dell Laptop Technical Support number, Read More http://www.delltechnicalsupportphonenumbers.com/blog/steps-to-set-up-a-new-dell-inspiron-laptop-for-the-first-time
May 08, 2017 | Dell Inspiron Mini 10 Notebook
3 keys on dell mini 10 do not work. Just started. What is the best solution to fix.
Hi
If you are using windows operating system. I suggest you run the SYSTEM RESTORE.
Go to START, choose ACCESSORIES, choose SYSTEM TOOLS, choose SYSTEM RESTORE and choose restore date that your keyboard works fine. Use other restore dates whenever necessary.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Jun 04, 2011 | Dell Inspiron Mini 10 Notebook
I cannot get my new dell mini inspiron to connect to the linksys wireless router in the home network. it cannot even detect the network. How do I fix this?
Have you been able to connect your netbook to other wireless networks? Do you have anything else connected to your home wireless network? Can you see your home wireless network using a different computer?
If you can't see other wireless networks check to make sure your wireless card didn't get shut off. Usually there's an on/off switch on a laptop to do this, or a combination of function keys.
If you can see other wireless networks and just not your own, try the wireless network's settings on the router. If you do have some type of security, I'd start off troubleshooting with no security, then move up to WEP, then WPA, then WPA2 in that order, or at least as high as you can get with the options available on your router. It might be that your wireless network is too secure for what your Mini 10 can handle.
May 11, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini. How do I change Bios passwod. Don't know old one
where is the small watch type battery in Dell inspirion mini 10 laptop
Nov 01, 2010 | Dell Inspiron Mini 10 Notebook
My wireless on my Dell Inspiron Mini 10 has never
Your Dell may not have the wireless card driver installed.
Install the latest wireless driver.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
To setup your wireless router and the wireless card in the Dell, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 05, 2010 | Dell Inspiron Mini 10 Notebook
Dell Mini 10 resolution
Reinstall the graphic card drivers. The problem should be solved.
Sep 19, 2009 | Dell Inspiron Mini 10 Notebook
Wireless connection
Hi Kazmerr
Re: Dell Latitude d600
Assuming you already turned your wireless, your distance should be in range fom your router. Turn off and on the switch  or you can press Fn+F2 to start your wireless connection.If thats a no go check your wireless client  and make sure no other wireless client is installed ie. your ISP wireless connection manager.
Other work around for this is : make sure you have enabled or started your wireless client for windows by ff the steps below :
Win XP Sp2: start > control panel  classic view> administrative tools > services > then look for Wireless Zero Configuration and right click it and choose start or restart . After doing this you may check or view your available wireless network again.IF no go >
For winXP or VIsta ONLY
Go to start > control panel   { classic view } > system > device manager > Look for network adapter {+} sign > look for 802.11g wireless / or anything that says 'wireless' and make sure that theres no yellow question or excamation mark on it and IF none right click it and choose remove/uninstall> then restart PC > and try to view avaialable wireless again by ff the steps above.
{ tthis will refresh your wireless network hardware and software}
Note: for yellow exclamation marks or questions marks on your wireless adapter you MUST reinstall your DEll Wireless adapter. using you DELL System Recovery Disk.
In most instance it has somthing to do with your wireless switch on your laptop. With all possible steps porvided above doesnt woprk pls notify me. Thanks and good luck.
Jun 11, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
HP 2133 Notebook PC Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
