Question about Kenmore Dryers
How do you trobleshoot the control board on Kenmore Dryer
Heater relay isn't getting any control voltage. I'm assuming the control board (micro-computer) is the problem. But how can I be sure?
  • 351 Answers
Can i have the model number? heater relay? never heard of that before? is the element getting its 220? if not then your thermal cut out is most likely bad... worst case is the timer... let me know
Posted on Jun 26, 2009
The start switch start the dryer but shuts itself when we release the button
Several different components could be preventing your dryer from continuing to run when the start button is released. The wiring diagram and other technical information for your dryer are shown in the image below. When the start (PTS or Push To Start) button is pushed, the PTS contact is closed and voltage is supplied to the drive motor. Start voltage is also sensed through the blue/black wire that is connected to the P1-5 Start Sense pin on the control board. When the control board senses the start voltage, it normally applies 48 volts DC voltage through the Pink/Black wire to the motor relay to hold the contact closed between the two blue wires attached to the motor relay that supplies normal run voltage to the drive motor. With the start button taped down, the motor continues to run since it gets voltage through the closed start button. Since the motor stops running when the start button is released, it indicates that you have one of these 3 failures:
Broken or disconnected Start Sense wire.
Failed electronic control board that is not sending the 48 volts DC voltage through the motor relay Failed motor relay. Wiring failure between the components.
Since the motor relay and the heater relay are both exactly the same part, you could unplug the dryer and switch the motor and heater relay to see if the dryer will stay running. If it does, then you just need to order and replace the bad relay.
Jan 05, 2017 | Dryers
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
May 19, 2015 | Frigidaire Dryers
Where can I get the schematic for my Kenmore dryer 110.73952101
the schematics sheet is under the head unit of the dryer where the timer is. In some dryers, the ones with the bottom front tray, you can find it in an envelope along side the wall of the dryer.
Jul 06, 2014 | Kenmore 63942 Dryer
My Kenmore HE4 Electric Dryer won't start.
make sure you have 240 volts. if you do, you should have power. assuming you have power. check your door switch and belt switch. if those two are good, then you might have a bad relay on the main board. if you can solder and can get the relay locally or online, you could change out the relay. or just get new board
Oct 15, 2013 | Kenmore Elite HE4 Electric Dryer
I have a kenmore series 80 dryer that the heat has quit working. can you help
have you?.....Checked voltage, checked the thermal fuse, hi limit thermastat on the heater housing
Checked the element to make sure it isn't broken.
If it is newer have you checked the heater relay and or the circuit board beside the timer. and lastly make sure your dryer can vent out. Relays and board are in he control panel.
Best of luck. if you can't do these checks yourself you may need a qualified service technician to help you out.
Mar 03, 2011 | Kenmore Dryers
No heat
Hi!
The issue you are facing is due to the thermal fuse. If the thermal fuse is the problem, the dryer wouldn’t run.
First of all verify the voltage for the dryer by using multi-meter to measure the voltage at the dryer outlet to make sure you have 240v because the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the voltage is ok, then the most likely bad parts are given below. As always, you should use your meter and the tech sheet supplied with your dryer (hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
You need to check and replaced the bad parts to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | Kenmore Dryers
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
Apr 25, 2009 | Kenmore 67082 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Feb 07, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
