Question about Boating
Volvo penta 740 lower unit will not go down.
I have a 1991 regal with the volvo penta 740DP. The lower unit will go up but not down. I have replaced the tilt motor, all three sylinoids(even the trailer switch under the dash), redone the wiring, and re-ran the ground cable. I have drained and replaced fluid several times as well. I am stuck. Any one had this problem.
  • thomas foster
    thomas foster May 11, 2010
    does the motor hummm when you push the button?
  • 5,687 Answers
Kind of sounds like the trailer switch is in control. Many of these switches have lockouts and if you move the outdrive past the trip point the other solenoids are dead. Watch fingers. There may be a tilt switch on the water side of the transom in the pivot housing.
Posted on Jun 30, 2009
1991 Volvo 740 shuts off i replaced the fuel filter and still it shuts off any suggestions?
Have a fuel pressure test run. Your car is 20 years old and if the fuel pump has never been replaced that is more than likely your problem.
Mar 21, 2011 | 1991 Volvo 740
Timing for a 1991 volvo 740
Hi, this is how to align timing on a 1991 Volvo 740.
There are marks for all three. Cam and Aux shafts have dots on face of outer gear. Cam lines up with mark on rear timing cover(about 1 o'clock). Aux lines up with mark on seal housing (about 3 o'clock) and crank lines up with mark on seal housing (about 12 o'clock).
Take care
Aug 08, 2010 | 1991 Volvo 740
Where is the fuse box located on a volvo 740 1991 model
on the 1991 740 the fuse box is located behind the black ashtray, unless you have a 740se, in which case it can be located on the side near the door, like in the 760turbo and 780bertone turbo. good luck :)
How do i replace the turbo in my 1991 740 volvo?
You bring it to me along with the new turbo. OR you take it to another mechanic. It will require a full set of mechanics tools and careful attention to detail.
Mar 09, 2010 | 1991 Volvo 740
How to replace a Left turn signal on a 1991 Volvo 740
Hello. here is how you replace the front turn signal assembly on a 90-92' 740. First, twist the the black plastic collar loose to disconnect the wiring harness from the assembly. Second there should be 2 10mm bolts holding the assembly in place. just take the nuts off the bolts, then carefully pull the assembly out. Reverse the directions to install. should take about 5mins, unless the nuts are totally rusted. if so use some BP Blaster. Good luck :)
Jan 22, 2010 | 1991 Volvo 740
91 740 volvo auto trans that wont go into
check overdrive or shift fuses. look in owners manual for location
Jan 09, 2010 | 1991 Volvo 740
2000 regal boat were is the screw to drain fluid in out drive
Look under the foot of the lower unit on one side of the nose cone. Slotted head screw with magnet. This one is used for draining and filling with the top one being the indicator for it being full.
Oct 08, 2009 | Boating
Cant open trunk of volvo740
it may vary by model year, but my 740 has access to the trunk compartment by pulling down the rear seat arm rest and simply reaching through the flexible blind.
Dec 30, 2008 | 1991 Volvo 740
Boating Logo
650 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
