Question about JVC GR-D275 Mini DV Digital Camcorder
My computer doesn't not recognize my JVC GR-D275 camcorder.
According to the manual all I need is a USB cable which I have. But my computer says that there is no video capture device. I was told not to use the firewire because I have no port for it. I installed the Digital Photo Navigator Ver.1.0 cd that came with the camcorder. I also read on line that I mini camcorders do not require drivers. Any thougths?
Thanks
  • 81 Answers
Sack whoever told you not to use firewire - buy a card for your PC and cable suitable for the camera (likely to end up being a 1394 to iLink). USB is wholly unsuitable (1.0/1.1 is too slow and 2.0 not stable enough) for transferring video at the bitrates that come from DV. Firewire is designed almost exclusively for high-bandwidth applications such as this.
Posted on Jul 19, 2009
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Upload video
The USB on your camcorder is for downloading still pictures only. If you want to transfer video to your computer you need to hook up a firewire cable, which is to the right of the USB connection. Firewire is also known as 1394 connection.
Hope it helps.
Jan 26, 2009 | JVC Cybercam GR-D200US Mini DV Digital...
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
USB Cable not recognized by my PC
Good day, here's the link where you can find the driver for you cam.
driver
Jul 05, 2008 | JVC GR-D350 Mini DV Digital Camcorder
JVC GR-D275U Driver for mac
You would need to use iMovie. Most MacBooks come with this already installed but if you can't find it you might have to buy it from apple's website. All you have to do is open iMovie with the camera connected and on and import the movie into iMovie, then you can edit the way you want it to be. iMovie has some great tutorials as well. Importing and editing can take a while, however.
Nov 08, 2007 | JVC GR-D275 Mini DV Digital Camcorder
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
JVC GR-D275 Mini DV Digital Camcorder Logo
534 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
