Question about Epson Stylus CX9400Fax InkJet Photo Printer
Just replaced my ink cartridges and now cannot get the printer to work. All settings appear correct and I have unplugged it and restarted it a number of times. It is a CX9400 model
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Did you remove the removable tabs? Push down on the carts to be sure they are seated. Call Epsontech support. Then, Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
I have the same printer and use the CISS.
Posted on Jun 29, 2009
Printer does not recognize ink cartridges on Epson NX415 printer
do you have the correct ink cartridges,also make sure they are installed correctly if this all checks out then try to unplug printer for 30 seconds and then plug back in and let it restart
Aug 15, 2014 | Epson Stylus NX400 InkJet Printer
Have an HP Deskjet 3050 and just replaced a black ink cartridge 61 with a black ink cartridge 56. Got an error message that says: "Cartridge problem. At least one of the Cartridges has a problem." Have...
On the inside of the cartridge door is the number of the cartridge you must use in your printer. If you put in another number, the electronic chip on the cartridge will tell the printer what type it is and the printer does not want to work with the cartridge. In the chip the printer also keeps track about the uses of the ink.
If number 56 is allowed too, perhaps another cartridge is empty too.
I think you did remove the pink label from the cartridge before you inserted it. because that label will block the electronic connection between the cartridge and the printer.
The manual explains how you can see what cartridge is causing trouble. When the printer is connected to a computer you also can use the computer to find out.
Oct 29, 2013 | HP Office Equipment & Supplies
MP640 - After changing the ink-cartridge ,a message appear. "The following cartridge is unknown", U043
I would try opening the printer, make sure the ink cartridge is fully seated. Once that is checked, unplug the printer, wait a minute or so, then plug the printer back in and try to turn it on. If the problem persists, then try a new ink cartridge. If that doesn't work, there is something major wrong with the printer itself, and will be beyond anyone but a Canon repair facility to repair.
Apr 07, 2013 | Canon Pixma MP640 All-In-One InkJet...
I have changed the ink cartridges before but this time nothing appears on the screen to say which ink cartridge needs to be replaced.
Have you tried unplugging the printer? I would shut restart the pc also, then power up the printer. If that doesn't help you can try going to the manufacturers website and downloading new printer drivers and software.
Jun 07, 2011 | Office Equipment & Supplies
HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
Here are some steps can help you.
Use only New Original HP ink
Restart the printer
Rreseat the ink cartridges
Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
Restart the printer.
I hope this will be able to help you resolve the issue.
Thank you for choosing Fixya.
Mar 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
May 19, 2010 | HP Photosmart 3210 Printer
My printer is saying to replace ink i have (black is th eonly one that needed replacing ) but it insist on saying change 2 other colors printer says there full computer says replace so i did its still not...
o.k. it does seem like you are a good problem solver. I did review your manual but could not find much for this issue.
May I recommend opening door or lid to cartridges.
Pull all cartridges out including black.
Examine all the print heads on your color cartridges especially.
Clean all heads with a warm damp cloth.
Place cartridges back into printer correctly.
Close door and power off printer.
Now power off your computer.
After 1 minute...
Power back on printer.
Next power on computer.
hopefully this will reset the correlating memory for both.
Questions to ask?
Are you sure that the color has ink?
Are the cartridges old? They may be expired. They are programed with an expiration date.
finally if things just don't work :
I believe this is HP customer support number.
  • Technical support in English and Spanish—just call 800-474-6836
Mar 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
Acts like its printing but no ink on paper
Using HP Director, you should be able to check estimated ink levels by selecting Settings -> Print Settings -> Printer Toolbox and then clicking on the Estimated Ink Levels tab.
If the ink levels appear to be sufficient, on the printer control panel press Setup, 1, 4. This will generate a self-test report. If there is streaking of any of the 4 bars at the bottom of the page, the affected cartridge may need to be cleaned. If any of the bars are missing, the cartridge needs to be replaced.
To clean the cartridges, press Setup, 5, 1. This will print a page of patterns.
Mar 17, 2009 | HP Officejet 5510 All-In-One Thermal...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to reset printer after installing new ink cartridges
unplug the printer from the wall, then plug it back in, leave in connected to the computer though.
this may help. If not, cycle the power off then on, ....wait. if nothing happens, click on the printer settings and ensure that they are correct.
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Epson Stylus CX9400Fax InkJet Photo Printer Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
