Question about Westinghouse 26" LCD Flat-Panel HDTV
Shadow color change to blue green color om ny westinghouse hd tv.
Why the color change to kind of blue mix with green on my westinghouse hd lcd tv.
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: shadow on lcd tv screen
A shadow of any kind showing up on a LCD TV is going to be a defective LCD panel. If not under warranty your replacement cost for the panel (if available) will far exceed replacing the TV with a new one.
Posted on Jul 23, 2009
  • 92 Answers
SOURCE: bad color
Chances are it is the connector on the "lvds" cable where it attaches to the lcd controller board. Detach the connector and clean any glue or tape residue off of it with isopropyl alcohol or electronics cleaner and then reattach it.
Posted on Feb 12, 2010
roety
  • 585 Answers
SOURCE: Westinghouse HD Flat Screen 1080Pure TV - Shadows
Image burn can be permanent if the image was left on for a long period of time. You can try a pure white screen to balance the screen out. They sell DVDs online that have white screen and other screen correcting images to try an correct the damage done to your panel. here is one linked plasma or LCD both can burn.
best of luck
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Jul 14, 2010
Testimonial: "Thanks for your help Roety!"
The colors of the tv are fine except for the blue, things that should be blue are green
The board that called the T-Con board it is could be dead.This T-Con board control the out put tv signal to the tv LCD screen panel.This T-Con board sit at the bottom in the middle bottom of the tv LCD screen panel. Take the connection out of the T-Con board .Tries clean the connection of the board with some rubbing alcohol,might fixed the problems,if not.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-Con board for the replacement.
Jun 01, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
My tv looks like it has double screen....for example a picture of a tree....right next to it would be another tree....double vision...
This is not a LCD tv,It a DLP tv.This tv have a problems known as Convergence problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be change to fixes 3D pictures,shadows colors pictures and Green,Blue,Red colors misaligns,don't matches up to form a good picture.The shop will u $300-350 for parts and labors.
May 24, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
The skin tones on people's faces are different colors and shadowed and I can't find my owner's manual.
its ok, pause the screen and get a wax crayon the colour that you want the peoples faces to be and colour over them on the screen. when you have fully enjoyed that frame scrub it off and pause the video 1 second later. eventually you will make the whole movie like this the exact colour you want it.................
Apr 19, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Shadow on lcd tv screen
Jul 23, 2009 | Westinghouse Televison & Video
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Westinghouse 32" LCD TV
It seems your pixelsare burning out. contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Jun 24, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
Apr 28, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Westinghouse 26" LCD Flat-Panel HDTV Logo
177 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
