Question about Microsoft Windows XP Professional
Company Share Drive access error.
Dear sir/madam,
I having problem here when i try to access to my company Novell share drive. when ever i click at any share drive, i get a message showing "0.exe" "Windows cannot find '0.exe'. Make sure you typed the name correctly, and then try again. To search for a file, click the start button, and then click search."
If i using another computer to access my company Novell drive, no message box will appear. May i know is it my pc infected by virus? Any solutions for this problem?
  • Edmund Ngan Jun 26, 2009
    Hi Kilroy2u,
    all the drive is mapped once i login to Novell. the thing is that when i double click on the mapped drive, it will show the error message. but if i try to login using another machine and double click at the mapped drive, no error message will appear.
  • 3 Answers
Is the drive mapped if so you may need to attach the drive again look under mapped drives and if it dont show there then click on tools map drive select the appropate drive letter and path you can look on another machine just click on my computer tools map drive get the info write down and type it or click over to it select it and bam your back....
Posted on Jun 26, 2009
  • kilroy2u Jun 26, 2009
    you still need to remap the drive and restart the computer Ive seen this many times
One of my pC is a part of nework and not allowing to access from anothe netwok pc , showing error message, Where as from this PC i can access another PC with network Tried no. of solution , but no one is...
First of all, you check the workgroup of your PCs. if the system is seeing other PC on the network. then you follow this steps. To know the workgroup of your systems. right click on the My Computer and point to Properties, Click on Computer Name, There you see options
1: Computer Description: You can type the name of your company like John Cybercafe
2: Full computer name: the name of the PC like System01 or Machine01 etc...
3: WorkGroup: is a collection of computers on a local area network (LAN) that share common resources and responsibilities. If you use the default setting which is "WORKGROUP" workgroup normally be on capital letter.Any name you use as your workgroup, make sure you use it on all other PCs to avoid conflict. Now click on Network ID, Next-you see two options, select the first options and click Next, you see two options again, select the second option which is "My company uses a network without a domain" click Next again, you see "WORKGROUP" leave it as it was and click Next, click Finish. A window will pop out telling you to restart your computer. Do you want to restart? Yes and Cancel, click Yes to restart the system. After restarting your system. Connect your network cable to the system or if is already connected. Go to Control Panel, click on Network Setup Wizard on Network and Internet Connections. Click Next---Next--There you see two options. select the first option and click Next, you will see another options
Computer Description:your company name would appear there like "John Cybercafe" in capital letter
Computer name: System01 or Machine01 in capital letter etc.........click Next to proceed. Another option is WORKGROUP. Don't change it to anything, make sure the name you used for your workgroup is the same thing with other computers.click Next again. This is where you have problem.
1: Turn on file and printer sharing: your computer will see other computer on the network and can share file and printer to each other.
2: Turn off file and printer sharing: your computer cannot share file and printer to each other, they can see each other on the network, but they cannot access each other. select the first option and click Next--Next, wait a moment for the system to share file and printer.after that,you will see four options, select the last option which is "Just finish the wizard, I don't want to run the wizard on other computers and click next and finally Finish.Now go to view my workgroup computer and access the computer again. Thanks and Good luck......
Jan 19, 2011 | Computers & Internet
Can't Share Files/Folders over home network
That sounds more like the security settings on the pc are not set correctly. Should be nothing to do with the card or the laptop. This is just a windoze thing.
Share a drive or folder on the network To share a drive or folder on the network
  1. Open shortcutcold.gifWindows Explorer, and then locate the drive or folder you want to share.
  2. Right-click the drive or folder, and then click Sharing and Security.
    • If you are sharing a drive, on the Sharing tab, click If you understand the risk but still want to share the root of the drive, click here.
    • If you are sharing a folder, go to the next step.
  3. Do one of the following:
    • If the Share this folder on the network check box is available, select the check box.
    • If the Share this folder on the network check box is not available, this computer is not on a network. If you would like to set up a home or small office network, click the Network Setup Wizard link and follow the instructions to turn on file sharing. Once file sharing is enabled, begin this procedure again.
note.gif Notes
  • To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer.
  • When you share a drive or folder, anyone who has user access to the network can read the contents of that drive or folder. If you want to remove the drive or folder from the network, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, clear the Share this folder on the network check box.
  • To allow complete access to the contents of your shared drive or folder, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, select the Allow network users to change my files check box.
  • To change the name of your folder on the network, in the Share name text box, type a new name for your folder. This will not change the name of the folder on your computer.
  • If you are logged on as a guest (a guest account provides access to the computer for any user who does not have a user account on the computer), you cannot create a shared folder.
  • The Sharing option is not available for the Documents and Settings, Program Files, and WINDOWS system folders. In addition, you cannot share folders in other user's profiles.
Apr 05, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
Can't acess laptop computer but can see on desktop
To allow access between both the laptop and desktop the hard drives or folders on both computers must be made shareable.
Right click on the C drive or folders or other hard drive then click on Sharing and Security - Sharing. Then in Network Sharing and security - tick Share this folder on the network and enter a share name that identifies this computer and drive/folder.
Apr 05, 2010 | Linksys Wireless-N WRT150N Router
I want to take the hard disk out of my Dell Inspiron 5100 laptop so I can copy it. Do you know how to access it?
Sir,
I have a better Idea which would not requrie any opening of Laptop. it is Take a one Lan wire and then plug its one end on your laptop and another end on other computer or laptop. Now start sharing like chose the drive you want to share and then right click on the drive and chose share it would tell you some things which would mean not to share but you can share it any way and there your data would be sent on other laptop or computer easily without taking out your harddisk. If any clearification requried reply here.
Nov 26, 2009 | Dell Inspiron 5100 Notebook
I have a shared folder with files in it. I disabled one share, then the rest of the shared folders went gone. how will I recover the data in it?
Hi sej_nb5,
A shared folder is only a way to access data files from multiple computers. If you are using the external drive, you will need to go and click on ":My Computer" and then find that drive, It will be called "E drive" or "F drive" in the list, and when you click on that drive you will have access to the entire drive, and you will need to navigate to those folders and files. You can re-share the drive when you get to the folder that you want by right clicking and choosing share.
Good Luck,
Mark
Oct 07, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi, how can be mapped the novell drive with vista ?
With the introduction of Windows Vista, mapping network drive to the Novell server without using the Novell Vista Client is still possible. In order to accomplish this, you have to make some changes with the way Vista authenticate.
•Open Control Panel
•Administrative Tools
•Local Security Policy
•Local Policies
•Security Options
•Double-click on Network Security: Lan Manager Authentication Level
On the drop down box, you want to change/select “Send LM & NTLM – use NTLMv2 session security if negotiated”
Note: The above menu driven is available with Vista Ultimate, Vista Business and Vista Enterprise. If you don’t have that version, you can run regedit and modify this key:
•[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa] “LmCompatibilityLevel”=dword:00000001
Once this is done, from windows explorer, you can click on map network drive and fill in the pertinent information such as \\servername.sscnet.ucla.edu\share.
•If you Windows local account is the same as your Novell login ID, then you don’t have to do anything.
•If it is different, you can choose to login using a different user name.
Aug 04, 2009 | Microsoft Windows Vista Ultimate Edition
Users cant get access to share drive
there is some security rights issue check that for that user ou user has set permisson of read and write and full check its ou security rgihts also check user group.
Jun 23, 2009 | HP Business Desktop dc5700 - Intel Pentium...
Network access denied
Follow the steps to Sharing the files
Your computers are already connected to a network — i.e., they’re all already able to browse the Internet using the same router..
1 : Open the Network and Sharing Center window by clicking on the Windows orb in the lower left corner, and then either right-clicking on Network and selecting “Properties”, or opening the Control Panel and double-clicking “Network and Sharing Center.
2 : If your network type is “Public,” you need to change it to “Private”:
  1. To the right of the network name and location type, click Customize.
  2. In the Set Network Location dialog box, click Private, and then click Next.
  3. In the Successfully set network settings dialog box, click Close.
3 : Under “Sharing and Discovery” in the bottom half of the Network and Sharing Center window, you need to turn all the settings from “Off” to “On” by clicking on the down arrow next to each setting, clicking on “Turn on …”, and clicking on “Apply.” But see some pointers below:
  1. For the “Password protected sharing” setting: you may want to leave this “On” or turn “Off” at your discretion. (I turned mine off.)
  2. For the “Public folder sharing” setting:
    1. If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    2. But if you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
4 : You’re done with the Network and Sharing Center window. Close it via the “X” button.
5 : Click the Windows orb at the lower left corner of your computer, and click on Computer
6 :
n the Computer window, navigate to the folder containing the file(s) or folder(s) that you want to share — e.g., “Pictures” or “Documents” or a specific file or folder within. Note: don’t open the folder itself that you want to share — just navigate to the folder that contains this folder.
7 : Right-click the folder that you want to share, and then click Share. The File Sharing window is displayed. (Click picture for a larger version.)
8 : If you have password protected sharing enabled: Use the File Sharing window to select which users can access the shared folder and their permission level. To allow all users, select Everyone in the list of users. By default, the permission level for a selected user is Reader. Users cannot change files or create new files in the share. To allow a user to change files or folders or create new files or folders, select Co-owner as the permission level.
9 : If you have password protected sharing disabled (like I do): Click the drop-down arrow inside the blank field in the File Sharing window, and select the Guest or Everyone account. Click “Add.” Then for that new account, click on the down arrow under “Permission Level” to change it to Co-owner (if you want anybody to read and modify files) or leave it at “Reader” (if you want other computers to just read but not modify your files).
10 : Click “Share”, then “Done.”
CRITICAL NOTE: If you selected “Everyone” when sharing a folder, you’re also making its contents available to any computer that joins this network. Many households, including mine, have wireless Internet via a wifi router. If you don’t have WEP encryption turned on, then I could just drive up and park on the street near your home, open my laptop, let it join your network via your wifi, and then nose around through your files. It’s particularly important that you have WEP encryption turned on for your wifi network.
Feb 18, 2009 | SAMTRON 55V 15" CRT Monitor
Installing Netware 4.11 in SATA PC
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
377
Jul 13, 2008 | Novell IntraNetWare 4.11 for PC
Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Nov 12, 2007 | Western Digital 500GB My Book World...
Microsoft Windows XP Professional Logo
88 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
