Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
I installed the printer server on my computer
Now my computer takes about 1 minute to load a webpage. I have another computer connect to the hub and everything is perfectly fine with it. I'm not sure what options I changed but something changed on my browser. Have you heard of such a thing.
  • Benjamin Kenny
    Benjamin Kenny May 11, 2010
    What operating system are you using? XP, Vista, Server, UNIX or LINUX??
I have the same issue. I can view the print servers web page from my Vista computer but not my XP. With Internet Explorer, I just see 400 in the upper left hand corner for several minutes. Then the page will partially display. If I use Mozilla, I see the html source. I have called D-link and they are useless, they want me to contact my computer manufacture. My guess it is a browser setting or some plug-in is required to view the page. The first time I accessed the page from Internet Explorer, I got an information bar at the top of the browser asking if I want to enable INTRANET security.
Posted on Aug 02, 2008
The dialog box says the printer is offline
Unplug the printer from the power. Turn off the computer and then restart the computer. Plug the printer back in. Let us know what it does.
Aug 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
My epson stylus tx 121 doesn't print..... it says ur printer s not ready... but everything s ryt at my end.... i need some solutions
First how are you connecting to the printer? Is it a direct USB connectionor are you using a USB hub or print server (sometimes part of a router)? If a USB hub is in use, is it a USB powered hub or a self-powered hub (AC adapter)? (Make sure that the printer has power and is turned on. Also make sure that you have printed and scanned a calibration )
If you are not using a direct connection, try a direct USB connection. Use a different USB cable and try different ports (some ports have lower power throughput than others). Make sure that you have the correct driver for your OS. (The full software is useful for other issues.) See for the drivers.
Try uninstalling the current printer driver and then disconnect your data cable (USB). For Windows, press Start and open the Devices and Hardware control panel (Printers and Faxes in XP) from the right hand column. Right click on the printer and select Uninstall (or left click and choose Uninstall from the Menu bar). Reboot the computer and install the Epson printer driver before reconnecting the USB cable. (Otherwise you can get the OS driver that may not work as well.) Remove your data cable from both the computer and the printer and turn off both devices. Unplug the power cord from the printer and the wall outlet. Wait a few minutes before reconnecting the power. (This will reset most printers if there is an error in the printer itself.)
If you are using a print server and the direct connection worked, check the installation information for using the print server. Not all printers are compatible with certain print server drivers and you can have a conflict.
If a direct connection to any of your computer's USB ports does not work, check if other USB devices work. If not, try updating or uninstalling your USB controller (in the Device Manager for Windows - Start > Control Panel > System and Security > Device Manager, scroll down to the Univeral Serial Bus controllers). Then reboot your machine and see if the correct driver installs. Alternatively, check your computer manufacturer and see if there is an update for your USB driver.)
If the problems persist, you may have a bad USB port on the printer. Please add a comment with the type of connection between the computer and the printer.
I hope this helps.
Feb 23, 2012 | Office Equipment & Supplies
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
I can't connect to the internet using my Acerhub 508D.\r\nIf I connect to the internet without the hub it works fine. When I try to connect to to look at my hub settings I get a message that...
Question 1: Is this a home network setup?
Question 2: Which system is set as the server directly connected to the hub?
Question 3: Have you tried or to connect to your hub?
Nov 22, 2017 | Acer ALH 508D (91.AB849.001) Networking...
How we connect 5 computers to one samsung scx-4300 printer?
Purchase a multiport hub. Then connect the computers to the hub and printer and install the printer to each computer.
Aug 13, 2010 | Samsung Computers & Internet
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
We have 4 computers they are all connected wireless. One minute you could print the next minute you can't. unplugged turned off and still not able to print... what gives?
Is your printer wireless also or all 4 pc are just sharing the printer on 1 computer..if the printer is wireless better reconfigure it again on your network...but if the printer is shared better setup a new workgroup/network and do that to all four pc..hope this helps...ITTech7574
Aug 31, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Can I wirelessly network my HP Officejet J5780 printer?
What you are saying will not work . The J5780 only connects with a USB. It does not have a J45 connection. So to play with the "built in network server" would do nothing. You would have to have some way to convert the USB to a J45 so he could hook it to his Wireless Router. His only alternative is to hook it to another computer that is used as a Wireless Slave that is shared or to get a print server. Hower, Belkin does make a wireless USB Hub that converts 5 USB's to J45 and can be hooked to you Wireless Router. It also has a built in Print Server. You can take this device and instead of hooking it J45 to the Router you can hook it to a linksys Bridge and now the USB HUB from Belkin becomes completely wireless. And has a Print server to boot! The model number are Belkin "Network USB Hub" and the Linksys WET54G.
Since the Hub connects to the USB devices and then converts them to a J45, to link to a network you can hook it to the llinksys device and convert it to a wireless network usb hub. It also has a print server built in.
It works. I own the same printer all in one and if you search on the internet you can pick up both devices on the cheap.
Jan 05, 2009 | HP Officejet J5780 All-In-One InkJet...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
